Six-dollar dash upgrade
Old 01-31-2008, 03:41 PM
  #191
UCLA JK Rida''s Avatar
That's a trick little upgrade on the vent trim rings...and a BARGAIN, to boot!
Russ D.
Old 02-01-2008, 11:11 AM
  #192
scouter4life's Avatar
Originally Posted by JMP8562
hey grant looks GREAT what paint did you use- dealer- or?
I was the original guinea pig (or at least the first to post it) for the sterring wheel painting. You can only do it on an '08 Sahara, but otherwise, I'm not sure how you would do it. On the '08's they have a silver cover on the spokes that comes off fairly easily, just pull up slowly on them from the outside and they will come up. There are little pieces on the back of them that hold them in place, some may break, but don't worry, it will go back on and hold.
To reinstall, just reverse the process, take it slow. if any of the little tabs bent, totally remove them as it will not sit right if they stay on. If you have any issues with it sticking in place, just use a little glue and they will hold. I've had mine on there for 3 months aand have had no need for glue.
Old 02-01-2008, 01:09 PM
  #193
A'sJK's Avatar
Originally Posted by mt3
i'm looking to do the ring on my gear shift (manual) .... does anyone know ... does it just pop off?
Yep.....i did it and am pleased with the results
Old 02-02-2008, 06:18 PM
  #194
USAF_GroundRat's Avatar
Default I did it!!!
Thanks for the help and inspiration, ArmyCop!
Old 02-06-2008, 12:03 PM
  #195
A'sJK's Avatar
Hey groundrat.....nice glock!
Here's how mine turned out so far!
[/IMG]
Great thread!
Old 02-06-2008, 12:39 PM
  #196
[/IMG]
Great thread!
Thanks brotha...
Hey man... you have a problem with that pic in your post.
Old 02-06-2008, 03:41 PM
  #197
run43v3r's Avatar
Grant, the steering wheel job looks awesome! PROPS to armycop, this is a great mod. Price/effect ratio is off the chart. I did mine and they look great and are holding up phenomenal after 2 months and quite a bit of abuse.
Old 02-06-2008, 03:51 PM
  #198
A'sJK's Avatar
Go to "myjkforum" beneath my name to view the paint results.
I'm still trying to figure out how to load pictures.
Old 02-10-2008, 09:27 AM
  #199
Bluewaterrider's Avatar
Question Shifter ring removal
How do the shifter rings come off??
Thanks BWR
Old 02-17-2008, 03:36 PM
  #200
A'sJK's Avatar
Just pry them off with your fingernail.
Quick Reply: Six-dollar dash upgrade
