Six-dollar dash upgrade
#162
The silver pieces come right off, you may break the little clips that seem to hold it in, but it went back on just fine and hold as well as before. Just be slow taking off and putting back on.
#164
I could be wrong though
#165
#169
I did this mod also but with a little change. I decided to do my gauges along with the vents, but I just wanted to do the rings around the gauges and not the whole gauge pod like some did, I thought that too much silver wouldn't look as good. So I taped everything off and took my time with it and it turned out great. Here are some pics. Really looks good with the dark interior:
Was it hard to pull off the cluster? I don't have a service manual so I'm a little nervous to screw something up.
Thanks!!!
#170
When you did this mod to the gauges, did you use the spray paint or did you brush it on? If you used the spray paint, how'd you tape everything off? I was thinking tape everything then use an exacto-knife or something and cut out the parts I wanted to paint...
Thanks!!!
Thanks!!!
