Six-dollar dash upgrade
#111
I tried this - I originally painted my vent rings in Jeep Green, but wasn't too pleased with the contrast between the dark gray and the green... if I had a khaki interior, I would've left it alone like that, but there just wasn't enough contract for my taste. So, I repainted them using a can of "hammered silver" paint, and then hit it up with a couple layers of "triple gloss." It looks really cool like this. I also painted the two side pieces of the passenger dash grab handle, and that looks really sharp...
#113
Vent Rings
Just grab the vent ring portion and twist, about a quarter turn. You shouldnt have to twist very hard. It should pull straight out then. You remove the rings from the vents, by opening the tabs on the sides. You should see them easily enough. Several posters have more detailed info earlier in this thread. Good luck!
#114
thank you, i was trying to remove the vent itself I managed to get it out with your help!!!! however I was too simple to actually look at how the piece came out, so it took me a while to get it back in but I managed!!! so now it's off to buy some paint!
thanks again
thanks again
#115
Can I take all the paint off the bezel by soaking them in acetone or something? I believe i have way to much paint on it now and the edges look kinda shoddy.
#116
It would depend on the paint - I don't recommed that approach, though... I think a gentle sanding would be a little cleaner/safer for your plastic.
#117
I'll post some pics as soon as I get a chance. If Wednesday comes without pics from me, please PM me a reminder...
#118
Will i did this last night, i paited the air vent rings and took apart the cluster and painted just the rings in there too. It was super easy. When i went to put them pack on they were dry to the tough but when i put pressure on it, it left my fingerprints in the paint. So i just pressed them all against my jeans and now they have a nice brushed aluminum look with a lil texture.
#120
Supposedly it takes about 5 min. Just pull under steering column trim off. Then unscrew the two bolts. Raise up and pull on the bezel and it pops off. Then 4 screws.
