Rock Rail Trimming
Old 04-11-2008, 07:13 AM
unlimitedone's Avatar
x2... How thick is it? Could I cut it with a hacksaw?
Old 04-11-2008, 10:33 AM
swampdonkey's Avatar
The rail is fairly thick. I used a cut off wheel on my grinder. I suppose you could use a hack saw, just might take some time.
As for the coating, I got some 3M undercoating in a can at the Walmart. Make sure you make a straight cut, and the plastic end cap will snap back in place, making it look factory.
Old 04-11-2008, 10:42 AM
Dustoff '68's Avatar
Not me bro'...
Old 04-11-2008, 10:55 AM
sgmrock's Avatar
Nice job! I have the Rub Rails and thought about doing this too...I need to check if there is enough room to cut..
Old 06-21-2009, 06:22 PM
Matt D's Avatar
Hey, I have a question for Mike..
Mike, how did you secure the end caps back on? Did you drill a hole to put back in the plastic retainer or did you use something else (epoxy). The end caps fit back in pretty loose.
For those who asked questions on how hard it is to cut, a sawsall went right though it....I would say either a grinder with a cutting wheel or sawsall would be best. A hacksaw would probably work, but it would take a while!
Matt
Old 06-22-2009, 11:39 AM
Ronson's Avatar
Took the rails off and used a sawall on mine . And then some black silcone for the caps . Still ok after 2+ years.
Old 09-17-2009, 07:41 AM
Nice write up I'l have to do mine before I put them on.
Old 10-14-2009, 12:43 PM
sjak's Avatar
Good weather, so I think I am going to go out and give this a shot!
Old 10-14-2009, 02:19 PM
Soopurman0's Avatar
its easy to do.. and to put the caps back on... drill a new hole and put the plug back in.... in the event of a broken plug on removal in the initial steps... they are like $2 for 15 at pepboys...
Old 10-21-2009, 11:08 PM
SoccerMan1080's Avatar
good write up!
Quick Reply: Rock Rail Trimming
