The Results are In....
#102
the sound bites that everyone has been posting sounds about right, I dont have a way of recording the sounds myself. The sound is noticable but it isnt bad at all. Driving to the fire station this morning, out on the highway, it really seemed to have more passing power and pickup, the sound wasnt really that much more at 70 mph than normal. I run 33's on 2.5 lift, six speed, 4-door soft top.
the model number was #12646---that is 2.5 inch inlet and outlet, 6 inch diam. and 18 inch muffler length, overall 24 inch.
http://www.magnaflow.com/02product/s...ne=main&id=513
I hope that link works,
I will post pics of the muffler sat morning once I get off from the station, if I didnt answer the questions clearly enough please ask.
I am building the air intake today also and will post "build out pics" along with material list once I get finished this weekend.
thanks to 1BADJK for the tech info. and the pm
Good luck and stay safe
#105
I finished my intake yesterday, and it is great, I have all the pics but I havent figured out how to shrink them to posting size. but I have the parts list:
1 k&n airfilter part # re-0910 from o-riellys 45.00
1 spectre vacuum/ sensor adapter kit part # 8711- its at autozone in the
import section. 6.99
1 spectre intake couple 21\2 to 3 inch part # 8751 "same location"
a 60 to 65 degree angle piece of 3 inch muffler pipe, about 2 1\2ft piece. You will need to cut down alittle.
I used a little plastic tote, cut down to size, Maybe be dumb to some, but it works prefect, and if your budget minded, it works great untill I can get to a machine shop. 5.00
I bought a 5\8 steel round stock for the valve cover hose,welded a 11\2 piece on, but now looking at the 8711 kit it has the grommets and adapters to get the job done. you will need a better drill bit the one supplied, stinks on this pipe.
Tighten everything up and go wheelin, I was impressed with the preformance and cost around 230.00 for everything muffler too.
If you are in houston and want to come to the north side I'll even help,
I'll send pics via email or if I can shrink them, I'll post them,
#107
And yes to ya'll that notice, I did break that lock on the sensor. heres the redneck airbox that didnt load last set. It worked really well on my measurements so.....
#109
Call it what you like but PLEASE don't call it a Hummer.. So sick and tired of being compared to a hummer... I had this guy in a hummer pull up and park next to me and have the nerve to make this statment " So, you bought the poor mans hummer." Never have I wanted so bad to beat the crap out of someone.. And I'm a nice guy.. I asked if he would like to take it to the trail with his "Bummer".. He just laughed and walked away.. So if some call it a "Truck", Car, SUV.... Whatever.. Just don't call it a hummer... wayoflife - you got it.. " There is only one JEEP"..
...........sorry to disappoint you guys -but I think I would have dropped him.
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
#110
The results are in.. I’ll keep this as short and sweet as I can..
Test and configurations were made to my 2007 Jeep Wrangler 4D Rubicon..
1st. Dyno run
Bone Stock = 198.7hp / 231.3tq
First we installed a Magna Flow True Dual Exhaust system keeping the stock catalytic converts in place..
2nd. Dyno run
Dual Exhaust System = 212.3hp / 241.1tq
Then we removed the dual system and re-installed the 2 into 1 collector and just ran a single back to a Magna Flow 6” x 18” muffler and then straight back..
3rd. Dyno run
Single Exhaust System = 213.8hp / 246.8tq
Obviously the Single System yielded much better results.. That is what stayed on.. And let me tell you the Sound is awesome..
Now the easy stuff AEM Brute Force Intake System.. Very Clean install..
4th. Dyno run
Single Exhaust System with AEM intake = 220.1hp / 250.7tq
Last but not least.. We installed the Jet Performance Stage II chip.. My initial thought process on this one was I wasted my money.. But the Dyno tell the truth..
5th Dyno run
Single Exhaust with AEM intake and Jet Performance Stage II chip
Final Results = 231.9hp / 258.8tq
Overall Gains = 33.2 HP / 27.5 TQ
Maybe to some this was a big waste of time but what the heck free use of a dyno and some spare time and some great Manufacture support.. Take these results as you may..
I will work on getting some pictures up on the exhaust relocation and intake install…I will also work on getting the dyno slips posted up.. Thanks Jay
![](http://www.crazyoggs.com/exhaust1.jpg)
![](http://www.crazyoggs.com/exhaust2.jpg)
1st. Dyno run
2nd. Dyno run
3rd. Dyno run
4th. Dyno run
5th Dyno run
Did you use a dyno jet or mustang dyno? It is my experence that you lose around 15 percent on a dyno so if you started with 202 hp and you show 198 RWHP on your first run there was no power lost to the drive train?? This does not make any sense. Your stock run should be in the 160 RWHP range. Mods do work but your numbers just dont add up as I see them and hopefully you can explain to me how this was done.
I am looking to mod my jeep and want Headers, high flow cats and a good exhaust and a good cold air intake and some brand of chip and T stat and would appreciate any recommendations.
Thanks Paul
