Replaced stock sub with JL Audio and Amp
#33
Sound is great. It pounds for an 8 inch. I plan on replacing all my stock speakers with JL Audio and retain the factory infinity amp. The amp is quite capable of pusing high end speakers. Check out my thread https://www.jk-forum.com/forums/jk-write-ups-39/stock-infinity-amplifier-amp-install-30571/ I have done a LOT of research, most will be pleased with the performance.
You said changing the OEM sub was worth it, even when keeping the factory amp. Considering I'm not too knowledgeable about speakers and such, do you know if the JL Audio 8W1 (http://www.crutchfieldcanada.com/JL_.../1368w1v24.htm) could be a drop-in replacement using the factory wiring, amp, etc.? Anything I should know about wiring it properly?
Thanks again for your great write-ups!
js.
#34
js.
#35
1 Post
Thanks for all your great posts! You say the factory amp is good... does this mean you've found a way around the soundbar filter???
js.
js.
For wireing purposes, the black wires are negative and the solid green wires are positive. You need one set to go to one side of the subwoofer and the other set to the opposite side. Remember dual 2 ohm coil will yeild the most power.
You can see here that the green is being soldered to the + wire and the black is negative or -.
As far as the rear speaker being made to have high output as well (removing the filter), I am working on it. I am trying to bypass the fiter so the amp will power the rear channedls at full power. Give some time. I dont want to destroy my amp.
#37
If you are to retain the stock amp and want to use it to power a subwoofer, you need a dual 2 ohm subwoofer! That one will not work.
http://www.crutchfield.com/App/Produ...l+2-ohm&tp=111
Let's say it's 1/4" too deep... What's the best material to build up the mounting surface? Cork? I also have some tar based tape I could use maybe...
Thanks!
js.
#38
1 Post
Excellent! Thanks! So then I would be looking for something like this:
#39
Any chance you could explain the difference on what 2/4/8 ohm differences are and how they would be wired? Maybe benefits of these. It seems that your knowledge on stereos is very broad. Thanks in advance. And this is a very nice writeup BTW.
