Relocated Sub Box
Relocated Sub Box
Hey Guys
I was bored and was about to make brackets for my box because of the tailgate shock I put in so while looking at it I said what a waste of space.
Why not put it somewhere else. Then BAM- it hit me!!
Again I did this and if you follow and mess up- Well its on you.
I decided it would fit and look best here!
I cut all the brackets off First then filed them down and torched them so the color would be the same.
Tip- Torching plastic brings scratches and filing scars back to original color.
I found this bracket in my garage
Used this mounting bolt
Put the bracket on and put double sided tape on the box side
Press the box on and took the bolt out
Drilled and mounted the bracket
Extended the wire
Bolted down the box
Final Look
Extended the wire
Bolted down the box
Final Look
I dont think so- because when the soft top is down the rear fold should cover a portion of the lower box.
Still have hard top on so I can't tell yet.
