Reds fender trim with detailed pics and video!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-03-2012, 05:53 AM
  #631
wpgwrangler's Avatar
ID:	336725Click image for larger version
ID:	336726Click image for larger version
ID:	336727Click image for larger version
Ok pics #1 & 2 show where I cut the skirt trying to follow the body line as close as possible, I started from the bottom and worked up.
Pic#3 is where I temporarily zipped tied the skirt to the body...couldn't find my steel bit.
Pic#4 is the rear of the flare where I noticed some movement ie: flapping if you will. What I did was slice off a piece of the cutoff flare and slid it between the body and the rear of the flare...actually snug it up nicely. I then used some clear silicon and ran it the length of the flare for good measure then painted over everything with some underguard.
I am sorry if I missed anything but everything will go smoothly as long as Red's instructions are pretty much followed .
I also couldn't get real good pics because of the glare from the sun but if more are needed I'll help where I can.
Old 07-03-2012, 12:55 PM
  #632
dethinator's Avatar
That is awesome, thank you for the additional pics and write-up! This weekend the fenders get chopped!
Old 07-03-2012, 07:48 PM
  #633
Mabeenate's Avatar
I think I'm gonna chop mine when I can find a set of Non painted ones. Anyone know if there is a difference between the four door and two door ones
Old 07-04-2012, 03:17 AM
  #634
Xman4602's Avatar
They are different.
Old 07-04-2012, 05:18 AM
  #635
sky
sky's Avatar
Did this last weekend, my trim edging started to sag off. It's only coming off in the corners so I bought a tube of 3m door edging adhesive seems to be holding up.
++ FREE MOD ++ Thanks Red!
Old 07-14-2012, 11:27 AM
  #636
Jeepcop's Avatar
Got the fronts done.... Now for the backs.
Old 07-14-2012, 11:46 AM
  #637
KY JK's Avatar
I added a small led running board light under the fender as a side marker. Really turned out well.
Old 07-14-2012, 01:19 PM
  #638
4WheelingAstronomer's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=340987"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=340988"/>
Looks great!
Old 07-14-2012, 08:04 PM
  #639
Attachment 340987
Attachment 340988
That does actually look good, after cutting the flare I thought "damn, why didn't I just cut the flare differently to incorporate the led like the BW flats".
Old 07-17-2012, 07:48 AM
  #640
A7x2706's Avatar
followed this write up a couple months ago and it turned out great. one of the best and cheapest...well the cheapest mod i've done.
Quick Reply: Reds fender trim with detailed pics and video!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
