Off-road cargo tray
Well version 1.0 has been used a few times for off-road trips, and it worked out great!
Now it's time for a few changes, since this is primarily for off-roading, I tend to carry a good bit of rescue/quick fix items and things that have come up in the past where something was needed but nobody had any...Automatic Transmission Fluid, Engine Oil, 24"/36" zip ties etc.
So I'd really like to have easier access to the two back corners, so I can tuck away the seldom needed gear, but still know it's there and not bouncing around...
The four mounting bolts are getting in the way, but I'm not satisfied with just cutting the short, they are in bad locations...
A good friend of mine is a 4x4 and motocross guy who also happens to have a large machine shop, and he does a lot of fabrication...so he's determined to find a different way to connect the board to the Jeep
With that out of the way I plan on adding a third row of adjustable tie down Trax
With three rows I can better fit the seldom used vehicle fluids kit to one of the two deep back corners, I can better accommodate both oversized and smaller sized gear bags, leaving more room for quick access needed bags.
All that with enough room left for a 45 quart cooler!
