My turn at using Raptor liner...
#41
Mark9998 - How long did you have to extend the harness?
#42
-WRM
#43
Originally Posted by TonyT
Yup, you can use conduit to protect them. I am going to go a step further and solder enough extensions on them to run the wires up along the roll cage. They will still go under the front door jam where I'll protect them with conduit, but then I'll route up through the B pillar and along the cage on the way to the back.
The plan is to do it Wed/Thursday this week. If the weather and my work schedule cooperates.
#44
I didnt take an exact measurement, but probably about 4-5' on each side. The only thing I can warn you about on this, when you initially cut your wiring harness, take a look at all the wires closely. Most of them are all different color patterns but if I recall I believe on both sides there are 2 seperate black wires that are pretty much identical looking. You will need to mark one of them so when you cut your harness you know which one is which when you are connecting them back up
#45
im so glad i found this post! i was planning on doing this this weekend with the raptor. I was also going to do the same thing you did with the rails and behind the bumper. im also gonna go ahead and take the fenders off and get behind them before i put on my tube fenders. great write up thanks for it! im sure it will help.
#46
UPOL using the tintable kit
Finally finished mine today using the tintable kit so it matches the deep water blue, here is the write up
https://www.jk-forum.com/forums/show...eep-Water-Blue
#49
Taking the carpet out of my unlimited now. Have the kit and will be doing prep/clean up over the next couple weeks then spraying the tub.
I'm thinking that when I get the caulking off the floor boards I may put in some fiberglass cloth as a heat shield. Then I spray over that.
edit:
DAMN!!!!!! That caulking stuff is tough!!!! Tried my Craftsman MultiTool on it and it just laughed at me. Chiseling it bay hand was not a good option. So I bought a air chisel at WalMart today. Maybe give that a try this evening.
edit:
#50
Spent 3 1/2 hours today with an air chisel taking out the crap on the floor boards and using a wire brush on a drill. Still not down to bare metal.
Yep, wetting the residual caulk or whatever that crap is helped to get it off easier with the wire brush.
Spent another 2 hours on it this past Sunday.
