MY Interior LED Upgrade
Old 05-27-2013, 07:05 PM
Smokey01's Avatar
Default MY Interior LED Upgrade
I have a few people ask me how I installed my LED's in the footwells. I figured I would just do a small write up.
On the passenger side footwell there is a cluster of wires. The yellow wire in the bundle with a white stripe in it is the dome the wire that controls the dome light. I figured if i spliced into that wire i could add some more lights. I tried it and it worked. The hardest part about installing this is squeezing yourself under the dash. I picked up some LED's at autozone. I had the wire connectors already. For the drivers side I could not find the yellow wire with the white stripe on it so I took an old cell phone charger and used the wire from that to run over to the passenger side and connected that wire to the same as the passenger side.
ID:	462273Click image for larger version
I figured that the dome light wire would have to run to the back door too so on the passenger side about the subwoofer I pulled the carpet back and spliced into the wire to add an LED strip when I open the rear gate.
I bought some LED's for the dome lights off of eBay. It came with about 12 bulbs (way more then needed). 2007 2012 Jeep Wrangler JK 4 Door Complete 12 Bulb LED Interior Kit 5000K | eBay
Old 05-27-2013, 07:10 PM
Smokey01's Avatar
The lights all turn on when the doors are opened and dim just like they did with the old yellow looking bulbs
Here is the finished product
ID:	462283Click image for larger version
ID:	462284Click image for larger version
And the left over LED's I put in the wife's Terrain. SUPER bright now.....
Old 05-27-2013, 07:15 PM
DesolationMania's Avatar
Thanks for all that effort. Looks good.
Old 05-28-2013, 05:39 PM
mOjO_JK's Avatar
nice job! so the wire in the rear was the same yellow with white strip? and what kind of LEDs did you use?
Old 05-28-2013, 05:46 PM
Jersey_Devil's Avatar
I might have to do this for my cargo area.... Great write up!
Old 05-28-2013, 06:41 PM
Smokey01's Avatar
Yes it is the same wire in the rear. It runs down the roll bar on the passenger side from the dome light.
I'm not sure what the name of the LEDs are at autozone but they had multiple ones in all sorts of colors. Any of them would work
Old 05-28-2013, 08:52 PM
mOjO_JK's Avatar
Im having a hard time seeing from the pic...which wire of the LED did you run to the yellow and did you just ground the other?
Old 05-29-2013, 04:22 AM
Smokey01's Avatar
What I did was test the wires first to see what was goes where. After I figured that out I just hooked the ground to the other ground wires that are already in the footwell
Old 05-29-2013, 04:43 AM
Firefighters_Axe's Avatar
Default Durka Durka.....
you'd figure Jeep would make this standard OE..... can't imagine they would have to raise their cost very much. Nice job and thank you for the replies back.
Old 05-31-2013, 07:39 AM
Zoglmann's Avatar
Autozone also sells a small led panel for the rear cargo light. Looked like the factory light was still in it in your pics.
Quick Reply: MY Interior LED Upgrade
