magnaflow exaust
#41
If some like diablo wer eto make a chip or ECU reflash then yes technically you could eliminate it. it would likely affect he car come smog time.
I think it is just the idle air controller gradually bringing the RPm's down.
When I test drove an 06 tacoma manual tranny it did the same thing. took for ever for RPM's to drop so you shift while mathcing revs to speed. thats why I went with the automatic.
#42
I thought the sound-clips were good, but I'm not a fan of any muffler that uses any kind of steelwool or fiberglass packing; The packing always breaks apart and rattles around until it finally comes out.
I'm a huge fan of Flowmaster. I had a built-up Tacoma with a V6, and I ran the Super60 muffler... This muffler will sound awesome and kicks serious butt.
#43
The clips sound great. I think I am going to run two Magnaflows inline, possibly buy the kit and add one under the drivers side. I am hoping they can cancel out most the sound without reducing to much flow, anything is better than stock.
#44
question...i noticed that stock exhaust system has a small dent on the pipe (when it goes over the rear axle) for extra clearance...
Will this be a problem when putting a full magnaflow system (which i assume has no dent)??
#47
Looks very cool! Where do the two pipes originate? Isn't the cat only a single out? What diameter are the dual pipes? I wonder how the back pressure is (or lack of) ...
#48
Got mine done today. First, there is only 1 shop within 30 miles of here that carries Magnaflow exhausts, and they only had 5 on hand. They didn't have a same side offset, but they did have an offset/center with 2.5. I didn't want to go with dual exits, so I chose that one.
Ended up not looking too bad. I wanted the pipe routed out the side rather than the rear. I don't know why, I just like it better that way. It sticks out a touch too far, I might be hacksawing it in the next couple days to get it back an inch or two, but for now I just keep small kids from running into it.
Cost less than $200 total, took about an hour. Fully welded, so less worries of leaks. The exhaust has a mild drone at around 3400rpms, but you can't tell I put an exhaust on at idle. It is very quiet.
#49
magnaflow
I had mine done yesterday, 6" by 18". They took the stock muffler off right behind the rear axle were it is bolted on, welded a ninty and put the muffler in the stock location of the old one, the did a ninty out the same location of the factory one was. You can tell the differance in preformance, putting my intake in today, will get pics up this weekend.
#50
man, i was deadset on getting the magnaflow exhaust until i heard the sound clips. i've been driving a v8 with flowmaster muffler for the past 3 years so the sound of a v6 with an exhaust kills me. i had an exhaust on an old v6 nissan truck before and i liked it. but then i moved up to the 5.3L chevy tahoe and got spoiled i guess.
geez, i was really excited about putting an exhaust on the jeep but i just don't think i can do it :( i guess i'll keep saving for some bumpers
