LoD Jeep JK Signature Series Rear Bumper Tire Carrier Installation Write-Up
Old 04-24-2009 | 10:11 PM
cojk's Avatar
Default 2nd Gen LoD Bumper
Eddie,
a couple of dumb questions. Just received my LoD bumper and tire carrier Gen 2. I've been trying to figure out how the rubber disk is suppose to be installed on the carrier, no instructions provided. Also there are 2 small right angle brackets I'm assuming they are hi lift jack supports?
Old 04-25-2009 | 03:38 AM
Lo2aY's Avatar
Originally Posted by cojk
Eddie,
I can probably help since Eddie's bumper was a prototype/first production and was re designed
the rubber disk goes on the rear gate to support the tire carrier from moving.
The two angled brackets go on the side of the carrier and they should have contact with the two bump stops also on the gate.
here is a pic of what i'm talking about
http://i250.photobucket.com/albums/g...r/IMG_0336.jpg
let me know if you need any extra help
Old 04-25-2009 | 07:24 AM
cojk's Avatar
Default Thanks for your help
Okay that makes sense, thanks for your help appreciate it!
Old 04-25-2009 | 12:29 PM
Lo2aY's Avatar
your welcome
I see your in CO
PM your number if you need an extra hand with it
Old 04-26-2009 | 09:52 AM
scotlandjk's Avatar
hey does anyone know what sort of bulb the rear lights use? pics?
i was thinking of just putting in a red bulb or a red LED one so they can be used as rear fog lights, as they are needed to be road legal here in the uk.
Old 10-22-2009 | 07:10 PM
47DRVR's Avatar
X2 on the picture. I just got mine and was scratching my head. IMHO for such a good looking product LOD could have spent 10 minutes on directions.
Old 02-11-2010 | 07:22 PM
MoridinTX's Avatar
WOL, thanks for the great writeup. I was reviewing the LOD instructions and came across yours as well.
One question I have is, how tight do we torque the different bolts down In the past I just go tight and leave it at that, but after working on the suspension, I am getting used to the idea of torquing down bolts to a specific amount.
Thanks for any additional guidance!
Old 04-26-2010 | 10:39 PM
llyrad's Avatar
Default Thanks for this thread
I would have been screwed without this write-up available when I did my install. Thanks a ton!!
Name:	Jeep 3.0 004..jpg
ID:	63439   Click image for larger version
Name:	Jeep 3.0 010..jpg
Old 11-17-2010 | 03:38 PM
amazonfrom503's Avatar
Default Bumper finishing install
Do you guys have any idea if the tire carrier Gen2 requires an extra piece of hardware to install a hi-lift jack?
I have an extra bracket too, what is this?
I cant get anyone at LOD to return my call or e-mails.
Tyler K
Old 12-20-2010 | 06:28 PM
RodCyn's Avatar
No other hardware is needed, besides the bolts/wingnuts to hold the HiLIft to the carrier. The HiLift is mounted along the top of the carrier, behind the top portion of the wheel. I had to take off my wheel to mount the HiLift.
lodoffroad.com/Jk%20Rear%20Install.pdf
I really don't know what that part that you have is for...
Attachment 102941
Tyler K
Quick Reply: LoD Jeep JK Signature Series Rear Bumper Tire Carrier Installation Write-Up
