JL Front End Conversion
man this awesome, jeep looks great!
Did you mount the flares with the LED's on? If so i would appreciate a write or message on how to. I want to just mount JL rubi fenders on my JK but i havent been able to find any write up. thanks
I have not tried to mount the JL flares on the JK fender but I believe it would take some work to adapt them to fit as I they are not mounted now curved the same.
I did not use the factory LEDs. I am running some basic Amazon turn signals as I cut the JL fenders significantly for clearance. Since this post, I have removed them completely.
Yeah i assumed they would require some adaption to get them to fit was just hoping you did to see what im getting into before i attempt, only difference is, i would be mounting them to the JK fenders instead of the JL like yourself. Thanks for the reply though.
Step 5:
Fender Brackets
Once your fenders are in the position you want them, now is when you'll make an adapter bracket to mount them on the JK fender enclosure/frame.
Note - the fender will have some spacing from the frame. There will be gaps since the JL is wider than the JK.
To mount the fenders, I made cardboard templates that ran along the JK fender enclosure and connected to newly cut JL fender. You may have a better way to do this, but I simply marked my JK mounts and then found points where I could secure the JL fender.
Once I was happy with my cardboard mock-up, I transferred the layout to metal. I tried to use as many of the factory 10MM points already in-place.
I used nutserts for the others. Here's the passenger side. I also used nut/bolts to connect the radiator support and bracket (see the two hex head bolts on far right side of bracket).
Here's what mine looked like when installed.
Fender Brackets
