IPF Headlight Quick Fix
#32
If you cracked that block badly, you will want to do something to seal it up against moisture.
glue, tape, shrink wrap, something to keep out the moisture as best you can
#34
Thank's but I think it's good ,just a real fine crack. Have spent the last hour kicking my myself. Was trying to get done before sun went down and completely forgot about the damn clips. It's a Wonder I was able to seperate them at all. Still I'll put a bead of glue over it first chance I get.
#35
trimmed! and then I also snipped the middle angle piece just a little (was a bit long, high and wide - look at the bulb you pulled and compare) and then it clicked right in tight - no zip tie needed.
I CAN SEE, I CAN SEE!!
