Installing after market tyre pressure & temp monitors
Old 01-24-2011 | 07:32 PM
hunty's Avatar
Default Installing after market tyre pressure & temp monitors
Hi Guyz
I am loving my new tyre dogs - Pressure & Temperature monitoring (realtime)
I added the monitors to hopefully save destroying an expensive tyre or two whilst wheelin - I have programmed the monitors for on road and off road;
On road the low pressure alarm is set to activate when a tyre falls below 30psi and I usually run between 32 & 35psi
Off road I set the alarm to a couple of psi below my aired down pressure ; if I am on sand and am running 12psi I set the alarm to 10psi
Hopefully this will allow me time to pull over and fix a leak before I have chance to shred them driving on a flat tyre - as all of you know its hard sometimes to know when you have a flat especially if you are in MUD!
I bought the tyre dogs that screw onto the valve stem - dumb@ss I hear some of you saying already.
Why;
1. I wanted to be able to remove them and use them on hire vehicles.
2. They are coded to the wheel position so if (and I always do at half way) I changed the front tyres to the back - didnt want to have to break the tyre bead. just to relocate the monitors.
3. I often tow a trailer and will take the front 2 off and put on the trailer when towing - as you all know when the trailer starts to feel a little soft / bungee to tow its too late - tyre already shreaded.
Tip
When I screwed them onto the valve they protruded past the sidewall of the tyre - this was clearly going to be a bad idea for serious wheelin so I took another handful of smart@ss pills and modified my rims!
I found a wheel mod friendly tyre store and had them remove my tyres and drill 4 additional valve stem sized holes and installed 4 extra valve stems - 1 in each rim! as close to the centre of the rim and as far as possible away wheelin danger.
Bonus
Not having to remove them & replace them everytime I wanted to Air Down & Air Up
I can now air up with the Mrs comfortable in the car with aircon on - all she has to do is toot the horn when the tyres are back to road pressure - I don't have to continuously check the pressure - can do other things like reconnect my sway bars, wipe mud from lights and number plates etc
Enjoy Cheers Hunty
Old 01-25-2011 | 05:39 AM
DROELLE's Avatar
Nice where did you get them and how much did they set you back $$$$$?
Quick Reply: Installing after market tyre pressure & temp monitors
