An Improved Grab Handle Solution
#141
I tired to get four handles from the local kayak shop, but they were sold out. so I came up with my own solution. I went to the local camping store bought 10 feet of black 1" climbers webbing, then when to home depot and bought a 3 foot section of clear 5/8" tubing. I cut the tubing to the handle width I wanted then cut the webbing to length. I fed the webbing through the tubbing and the punched, grommeted, and mounted the Handles. Now for the front I used the two screw pins for the door frames to attache the handles two. The only thing I did different was adjust the webbing length so they hung down the same are the rear. All told it took me about 30 minutes and I love the. Infact the dealership complimented me on them and wanted to know where I got them. :-)
#142
Nice job....
I have what is quite similar (if not identical) grab handle made by MP 4x4...purchased from Jeep Outfitter...they (the web straps) are oversized and fit any roll bar; again...super nice write up.
#143
Just reiterating that these are very good and very strong.
I pulled down on each one to test it with all my strength to see if they'd break.
I actually pulled the suspension of the Jeep down, handles just fine. VERY strong. P.S. - I'm 6'6" and 270 pounds. If they were going to break, they would have then.
#146
A little improvement suggestion.
I got mine in and as a added precaution, I dipped the ends of the handles in "Tool Dip" about 1 ". This holds the strapping material together as well as provides a better gripping surface for the grommets. I also hope it will help to keep the handles in working order longer. I hope this helps.
sorry about being cockeyed, it is not like this in the original image.
[IMG][/IMG]
The grommets were added after the dipping and then spay painted.
[IMG][/IMG]
#147
You can't throw that out there without pics. ;-)
#150
