How to stop drivers chair from Dropping! - Hunty's JK
Old 04-19-2011 | 12:53 PM
  #21
D0ppleganger's Avatar
I'll spell it out for you.
If you are tall > and you lift your seat > your head hits the soundbar.
Old 04-19-2011 | 04:16 PM
  #22
Jollydodger's Avatar
Let me spell it out for you, nobody cares how tall you are, and this thread is about the driver seat dropping from the desired position. What part do you not get?
Old 06-06-2011 | 01:51 AM
  #23
Love Monkey's Avatar
I totally was thinking I was can't wait to fix this! For some reason I can reach the gas pedal a little better when I am up higher.
Old 06-11-2011 | 08:00 AM
  #24
IcyFridge's Avatar
I just cut the handle off of mine and left the round part on. Works great!
Old 06-14-2011 | 12:12 PM
  #25
RANGER666's Avatar
brilliant.
Old 06-14-2011 | 02:43 PM
  #26
dowayno's Avatar
Originally Posted by hunty
Hi Guyz
I thought it was just me at first being 6'4 and 2ton - lol
but I posted a how to fix the annoying cabin air intake panel rattle and discovered I was not alone in slowly squashing down my drivers seat!
So here's the juice;
Some get a little rattle when the drivers seat is at its lowest.
Others (inc me) slowly sink down until they can't see out the drivers front window LoL.
The cause is simple
Every time you get in & out of your Jeep ESPECIALLY if it is lifted you turn and slide you @ss out over the lever and each time you "Sit on the lever" you lower your seat 10mm - 1/2inch
The cure also simple
1. Set seat to desired height.
2. Remove Lever! - pry off centre cap - loosen bolt
If some else drivers your Jeep and doesn't like the height of the drivers seat - just keep the lever under the seat and hold it in place whilst standing out side your Jeep and change the seat to the desired height - for me I say "Don't touch the seat height - I have it set as high as it will go and im 6'4 so unless you are heaps taller than me - live with it LOL
Enjoy
Cheers Hunty (Jeep Macgyver lol)
Dude, where was this post when I needed it last year. I had the dealership replace it last year. No improvements. Just poor design.
Great write up
Quick Reply: How to stop drivers chair from Dropping! - Hunty's JK
