How to fix annoying air intake / wiper motor trim panel rattle
Old 01-06-2011 | 02:37 AM
hunty's Avatar
Smile How to fix annoying air intake / wiper motor trim panel rattle
Hi Jeepers
If any of you guyz are like me you hate anything rattling on ya heap!!!!
I spent 30min the other day chasing what turned out to be the batteries in my mag light rattling - I know I have a problem lol need to take my meds LoL
Driving back to Adelaide from Australia's biggest motor museum I was forced to pull over in 39degC heat and search for another annoying rattle!! :(
after tapping and knocking every flare, guard and body panel I found the culprit!
It was the cabin air intake and wiper motor cover trim / panel. it was vibrating like a biotch on every bump and undulation I drove over :( - its a quick and easy fix!
1. Remove wipers by pulling plastic cover forward to reveal wiper lock nut .
2. Remove the 4 plastic Christmas tree type fasteners
3. Remove the 4 hex? head bolts - be carefull when replacing them as they are big girls blouses.
4. carefully pull cover trim forward just enough to clear the wiper shafts then up and out!
5. I used double sided tape - im sure there are better ways to stop vibration - if you are a panel beater or similar guru pls post up a reply!
6. re install - be careful to re align the wipers correctly and voila - no more anoying rattle
cheers Hunty
Old 01-06-2011 | 06:03 PM
delos001's Avatar
Originally Posted by hunty
Hi Jeepers
cheers Hunty
I'm checking this out this weekend. If its my rattle, ur getting a frigging Christmas card next year.
Old 01-07-2011 | 12:30 AM
NH-JK's Avatar
Ha! That's awesome.... Most would just turn the radio up. Good job!
Old 01-07-2011 | 08:17 AM
notenuftoys's Avatar
Hmmmm... I wonder if that's the rattle I've hearing. Mine seems to be worse when it's cold. Might have to give this a shot.
Thanks for posting!!
Old 02-07-2011 | 10:01 PM
theosdad's Avatar
I spent a year being twisted about this darn rattle. Last week I stuffed a pice of plastic under the intake area. I need to do this. Much cleaner. Thanks for write-up.
Old 02-08-2011 | 11:34 AM
dads jk's Avatar
Default rattle
Good job . I'm the same way , if I hear a rattle I'm pulling over to find it.
Quick Reply: How to fix annoying air intake / wiper motor trim panel rattle
