Hood Lift Fix that worked for me!
Old 04-03-2008, 07:33 PM
  #31
07 RBY's Avatar
Originally Posted by bswaltm
and as always miller light always helps invent
You're very observant. And 100% correct.
Old 04-03-2008, 08:08 PM
  #32
chucktuna's Avatar
Originally Posted by wiredawg_mg
I have a couple of very heavy tywrap that are used to hold phone cable splice cases to the sides of man holes that will be going on this weekend.
I will make sure next time down IL3 to at any Black JKs coming in from Smithton, welcome to the fourm.
Thanks for the welcome, wiredawg! I'm always running through Columbia whenever the wife needs to go to Costco
...BTW, I didnt get mine at Metro Chrysler, or whatever its called now.
chuck
Old 04-04-2008, 03:37 AM
  #33
Mark Doiron's Avatar
Originally Posted by Brad2893
Did any of you guys who put the buckle on the inside get any paint rubbing? Just curious.
Not an issue. Open up the latch and look where the wire tie will run and you'll see that it won't contact the finish; it'll nest snugly in the receiving half of the latch.
Old 04-04-2008, 04:56 AM
  #34
pearl-drum-man's Avatar
Originally Posted by Dustoff '68
Anyone contact Chrysler about this? Personally, I don't see the hood "popping" off...I only see the thin sheet metal of the hood "vibrating" (for lack of a better word) from cross wind buffeting...I don't see how the hood would suddenly open, unless the hood latches were ripped off by some bizarre force...and I don't see that happening anytime soon.
This was an issue on the TJ to, but seems that the JK has a lower threshold for this to happen. I took a couple minutes to remove the one bolt that holds the hood spring and removed it (the spring) and haven't had an issue since. By removing the tension of the spring, you basically increase the amount of outside interference (wind) necessary to create hood lift. No need for unsightly (IMO) zip ties to hold the hood in place.
As long as the metal latch is engaged, the hood will not open completely, it is the "slop" in that latch that allows the rubber hold downs to flex under moderate wind buffering.
Old 04-04-2008, 04:59 AM
  #35
Originally Posted by britjk
Or put your spare tire on the hood and pretend you're a land rover.
Haha, wonder what that would look like. Unfortunately the flimsy sheet metal on the hood would probably cave in.
Old 04-04-2008, 05:16 AM
  #36
sgmrock's Avatar
I love the quick and easy fixes...great!
Old 04-04-2008, 05:26 AM
  #37
wiredawg_mg's Avatar
chuck
Chuck sent you a PM, don't want to hijack anymore than needed.
Old 04-04-2008, 09:38 AM
  #38
I Drill's Avatar
take off the spring.
Old 04-19-2008, 05:17 AM
  #39
Colonel Angus's Avatar
Tried it this morning........I think I zipped one of them a little tight because it snapped when I tried to latch the hood back down. Should I take the one that didn't break off until I can get my hands on another tie wrap or will 1 be okay for the time being.
Old 05-20-2008, 06:20 PM
  #40
Geeper4x4's Avatar
Originally Posted by neoxxis
Update: The Ty-rap buckle is now inside...
Now the hood doesn't move anymore...
So I wonder what would happen to the hood if you go offroad, lift a wheel and torsion applies to the body...???
Any stats?
(Third time I write this... I hope you're not subscribed to all 3 threads!! )
I don't think you will experience enough torsion to the hood to cause a break.
Quick Reply: Hood Lift Fix that worked for me!
