Hood lift fix
#21
#22
On BYUCOUG's JK we only removed the spring. It has significant less lift. He did tell me the other day that still gets a little lift every once in a while. I might add He drives my a little old lady and not the one from "Pasadena". I on the other hand drive it like I stole it and I did the spring and the tube. NO LIFT! EVER!!
#23
Cool, I'm planning on doing the tube and removing the spring tomorrow, also planning on making an air intake tomorrow too... should be fun... it's budget mod time
#24
#27
I noticed the hood lift in my wife's JK yesterday. My JK doesn't do it and I've had the speedo so far that it wouldn't go any farther. When I popped the hood on my wife's I noticed she doesn't have a hood liner like mine does. Apparently, it was hit or miss in 2007 if you got one. The new 08s I saw on the lot didn't have them.
The hood liner is available from the dealer for A little over $100.
#28
I beg my jeep to get to 75, I dont see how you guys are reaching 85+. Perhaps it is my Central TX headwinds, but im scared of being blown off the road at 72ish. When I saw the white flex of the rubberbands and my safety latch catch at 77ish I have forever slowed down and just enjoy the ride. Of course with the BFG MTs on I cant hear myself think, which is significantly helping with the soft top noise
Heh, just for G&G's I ran it up a bit yesterday, hit a solid 100 then slowed down, it is not fully broken in yet. Previous high was 90 but I just had to peg it once. I was running my hardtop and had my wife in it too.
Now I'm going to really have to watch the hood, I have seen some hood flex but figured it was just thin metal.
An air dam by the radiator can create a negative pressure in the engine compartment and "suck" the hood down. Will also help with any heat problems at speed.
#29
Hood lift cured
I was relieved to finally cross this article that suggests a fix for my hood consistently bobbing up and down on the highway. After reading replies to the thread....about either removing the spring and/or adding the rubber strip, I was curious as to which idea would cure the hood lifting problem...or if both ideas were needed for my particular Jeep (2007 Wrangler X). With a 2000 mile road trip coming up, what a perfect time for experimenting.
Before my trip, I visited Lowes and bought the rubber hose and glue (about $10 total). I tossed them in the back of my Jeep in order to install sometime on my trip if the spring idea didn’t work out.
I decided to try the easier of the two ideas first. I removed the spring at the start of the trip. I crossed very high winds on my adventure. I even passed through a valley where hundreds of huge windmills spin in order to generate electricity. The valley is known for extremely high winds. The last time I drove my Jeep through the same valley, my hood consistently bobbed up and down for about 30 minutes of the drive. Talk about a freaky 1/2 hour.
My hood only lifted once (that I saw) on my entire 2000 mile trip by simply removing the spring. I still have the rubber hose and glue in the back of the Jeep ready for me to install at a moments notice if needed. However, so far, I am comfortable with the 99.9% reduction in lift simply by removing my hood spring.
#30
Yeah I had both for a little while, then the glue on the hose started to "unstick" so, I just took the hose out, and left it with the spring removed, and no hook lift at all, and i've been on a lot of road trips in the last few weeks.
so I would recommend just remove the spring and be done with it. that hose could do some damage if it got loose and ended up in the radiator fan or something.
