Help removing decals
Old 10-03-2008, 05:50 AM
  #71
Seir's Avatar
Yes, a little sun and a fingernail goes a long way. WD40 to cleanup any leftover gunk.
Old 10-04-2008, 06:29 PM
  #72
artiedib's Avatar
I used my wife's hairdryer and finished up with a bit of GooGone. Had both "X"s off in less than a half hour.
Old 10-14-2008, 09:25 AM
  #73
AlmightyCrash's Avatar
zippo fluid is good for residue...all of my decals, including the visors peeled right off. Just leave the jeep in the sun for a while first.
Metal emblems such as Trail Rated and JEEP can be removed by sawing through the sticky tape on the back with fishing line.
Old 10-22-2008, 05:32 PM
  #74
tcodtj's Avatar
heat gun or a bit slower a hair dryer
Old 10-23-2008, 07:19 AM
  #75
n6on's Avatar
Hair dryer and WD40 works every time!
Old 10-23-2008, 09:39 AM
  #76
greenjeep's Avatar
I like to use a grinder and blow torch for mine
Old 10-23-2008, 10:26 AM
  #77
RDY4RKS's Avatar
Heat em up. Peel them off. Get some wd40 or goo gone to get rid of the residual sticky stuff left behind. Also going to need a bit of elbow grease.
Old 10-23-2008, 10:53 AM
  #78
amff27's Avatar
I use soapy water a plastic sqeegee and a regular hair dryer. Not as hot as a heat gun no paint burn
Old 10-23-2008, 11:35 AM
  #79
dyolfknip's Avatar
Originally Posted by HawesEA2
I always thought brake fluid ate your paint off, that's why it says not to get it on any painted surfaces, and if you do to wipe and clean it up asap?
Did you also know they took the word "gullible" out of the dictionary because it really isnt a word?
Old 10-23-2008, 06:05 PM
  #80
artiedib's Avatar
1) Hair dryer,
2) patience, and
3)GooGone.
Heat it up a bit at a time, peel with your fingernail and refer to step #2.
Quick Reply: Help removing decals
