Help removing decals
Old 07-16-2010, 08:06 AM
  #101
goaterguy's Avatar
I peeled the Sport and Wrangler stickers of mine the same day I got it (last Friday), the Sport did not leave any residue but the Wrangler did.
I started with goo off but it started to take way too much time and rubbing.
A spray of silicone lubricant, wait a few seconds and it came out perfect and extremely quick!
Don't waste your time with the Goo Off, go straight to silicone lubricant.
Old 08-12-2010, 07:04 PM
  #102
mrktwatchr's Avatar
Citrus juice works well for the glue .. mix it with a bit of water and spray on ... has worked like a charm for me on other things with glue backs, just try not to let it run everywhere as it will clean what ever it is on ... and dont let it sit to long on the painted surface .. put iton and take it right off ... as with most cleaners it will etch if left to long ... Other wise just use a mild soap and water with some elbow grease.
Ive also heard that WD40 works wonders as well have never tried it but hey life is full of suprises and you have to try everythong at least once.
Old 08-12-2010, 07:20 PM
  #103
Rustler's Avatar
Took mine off today got rid of the X and wrangler stickers, good and hot here in Phoenix used my nails and peeled them off. Used wd40 to remove the glue then washed the area with soap and water and dried it off completely.
Added my new stickers.......................4 Wheel Drive and Jeep stickers
Old 08-13-2010, 05:48 AM
  #104
ATFPat's Avatar
When removing the "Islander" stickers I let the stickers sit in the sun. Using a heat gun, peeled them back which left the glue etc. Goof Off and elbow power to get that off and finished with a quick buff. Pain in the rear.....
Old 08-23-2010, 08:10 PM
  #105
BluMtn2010's Avatar
I used to drive an 04 TJ "X" left the "scarlet" letter on it.
I actually think its cool to see a rig with $6k in lift, wheels, tires etc and see an "X" on it.
Face it, non Jeep owners have no idea what X, Rubicon, Sahara or Levis means on the side of your Jeep. Only Jeep owners truly appreciate the time/cash you spend building a rig.
(bonus points if you remember what "Levis" meant to your rig)
Old 08-24-2010, 11:24 AM
  #106
dannytr84's Avatar
Originally Posted by RedRockJK
1) Drink Milk
2) Grow Fingernails
3) Sit Jeep in Sun
4) Pick Edge of Decal with newly grown Nail(s)
5) Peel away at sharp angle
6) Throw mangled decal in refuse container
Old 08-27-2010, 07:37 AM
  #107
oregon signs's Avatar
heat gun, plastic scraper and rapid-tac adhesive remover. less than 5 minutes total
Old 12-05-2010, 06:52 PM
  #108
bingote's Avatar
i just used alcohol on the remaining glue....
i wasn't that sure, but a friend told me he had used it before... i will remove the ISLANDER decals off the hood.
I just removed one tiki bob to test maybe 3 weeks ago and the paint is still fine... so i think i'll remove the complete decals tomorrow.... unless someone advices me on time not to with alcohol
Old 12-06-2010, 05:15 AM
  #109
DDloadedJK's Avatar
Goof off worked the best. Not goo gone. Use some heat too!
Old 12-06-2010, 05:24 AM
  #110
JaxLoki's Avatar
Let it set sunny side on a hot day and they peel right off. Goo gone or bug and tar will clean up the residue if any is left over.
Quick Reply: Help removing decals
