Hardtop hoist/storage write-up
Old 07-28-2012, 07:49 PM
  #411
MyMtnHome's Avatar
Originally Posted by kleinrider
I ink I'd be scared to put the hook straight on the hardtop for fear of causing damage long term. What kind of force are you exerting on that front lip?
You tell me. We are talking about a top that weighs around 150 lbs and all of the force is aimed directly back into the top. It's been hanging for over four months now with no negative affects.
Old 07-29-2012, 03:52 AM
  #412
kleinrider's Avatar
Uh, how would I know? I don't run the setup, so have no way of seeing how it's supported. If you're comfortable with it, go for it.
Old 07-29-2012, 04:42 AM
  #413
cfendya's Avatar
Originally Posted by bstpierre
No problem.
I'm a mechanical engineer so I have a soft spot in my heart for pulleys and ropes. :-)
So I got the top off using the strap method but the top seems all over the place. I think it all has to do with the strap location and trying to find it's center of gravity.
Do you happen to have a picture of the straps location on the top?
One thing I did notice from your pictures is you run each strap from the side to the center rear. I was running straight back and then bring the strap to the center of the top (as best as I can) to connect both ends of the strap to the lift hook.
Getting it off and on was a two person job because one had to keep the top stable in order for the other to drive out or back under it to get it back on.
Old 07-31-2012, 03:29 PM
  #414
bstpierre's Avatar
Ultimately you are lifting the top by one rope, correct? If you are using that method you will need to find the balance point. The t-bar makes it easier to fix that point. And use a braided rope. If you use a twisted rope the top will spin when you lift it.
Instead of doing that I have three ropes that go straight up to the ceiling, one at the rear center of the top and the other two are at each side by the door opening areas. That way is very stable. I wind all three ropes on to the same winch.
Old 08-01-2012, 04:06 AM
  #415
cfendya's Avatar
I understand now what you're doing. I just have the single cable from the hoist mounted on the ceiling. The tie down straps are routed under the roof, meet on the top and all hook on to the hoist hook. This is how I thought you were doing it minus the hoist.
Looks like a t-bar is in my future. Thanks again for all the help and suggestions.
Old 08-27-2012, 07:56 AM
  #416
cweichler105's Avatar
Here's a video I was working on for showing the installation of a roof rack and I included video of the hoist system I'm using to remove the hard top. It doubles as a bike/utility lift so I could get more use out of the hoist and felt others may have the same need. Thanks to the original poster for showing how to use channel struts to create the t-bar frame. It was exactly what I was looking to do and worked perfectly. Like a grown man's Erector Set.
https://www.jk-forum.com/forums/jk-w...imited-225366/
Old 09-03-2012, 06:39 PM
  #417
LIJeeper's Avatar
Newbie here
This was an awesome thread. Thank You for something else to put on my list
Old 09-09-2012, 08:29 PM
  #418
bobholthaus's Avatar
I drilled four holes in my top and used rubber washer. Warn 1700 winch on Amazon $99 shipped). About $30 in parts and carabiners. Hooked to old 12v battery I had laying around. Put silver vinyl stickers on my roof and freedom panel "humps" and I slide the freedom panels onto the roof upside down (vinyl to vinyl). Takes me less than 10 minutes start to finish, solo, to get my roof on and off.
Old 09-23-2012, 06:19 AM
  #419
Jrex's Avatar
Default Storage Unit
Has anyone mounted a hoist in a self storage unit? I am looking at a 15'X15' unit and wanted to know if anyone has ever mounted a hoist to be able to back into the unit and remove the top.
Old 09-23-2012, 05:54 PM
  #420
BosoxJK's Avatar
My simple rig. 4 ratchet straps, 2x4, chain and few eye bolts. About 20$ Takes less than 5 minutes with one person. Pictures aren't great but you get the idea. Really sturdy. Does not move hardly any once its secure
ID:	369715   Click image for larger version
ID:	369716   Click image for larger version
ID:	369717   Click image for larger version
ID:	369718   Click image for larger version
Quick Reply: Hardtop hoist/storage write-up
