Hardtop hoist/storage write-up
#154
I have a bulk head in my garage that gives me very little clearance over the back of my jeep, and then over the front I obviously have the garage door.
I only need to lift the top enough to clear the Jeep, then I can pull out and lower the top onto the cart that I plan on building...
My question is what is the best way for me to hoist the top...I was thinking of a 12v hoist on the end of the bulkhead, the cable will be routed under a pully then go straight to another pully located over the Jeep...
There is a pic below, you can see the garage door opener, I plan on mounting the hoist oposite the opener on the other side of the bulk head...any better suggestions? (from the pic it looks like the bulk head goes back to the wall, but it actually stops about 2ft before the wall and goes back up to the ceiling)
#155
front of Jeep
68"
44"
back of Jeep
68"
44"
back of Jeep
#156
you might want to just use 4 eye bolts and 4 cargo straps with ratches on them. this way you can just lift it alittle and wouldn't have to worry about a hoist or winch since you plan on making a cart.
#157
I thought about that, but lowering it all the way to the ground and then lifting it back up over the rear of the jeep will be a pain using 4 ratcheting straps...a hoist would make it much easier...
#158
Yes, I did this the first time, before I built the T from strut. It is slow & does not feel safe/secure.
#160
