Grill Mod
Old 02-24-2011 | 02:50 PM
  #911
damunoz32's Avatar
Got mine done yesterday and tried to help the adhesive by adding some hot glue. Unfortunately most of them had detached by this afternoon
I'm soaking them in wd-40 so I can remove the adhesive pads and redo it with some gorilla glue.
Old 02-24-2011 | 04:20 PM
  #912
2ndchance's Avatar
When I did mine, I didn't soak them in WD-40. I just used my thumbs and rolled back the adhesive. They came off pretty easily.
Old 02-24-2011 | 04:23 PM
  #913
damunoz32's Avatar
I gave that a try but it was kind of difficult to get everything off on mine. Everything should be back up and tied down by tomorrow.
Old 02-25-2011 | 04:06 PM
  #914
debsJK's Avatar
What is the best glue? I used alcohol, scuffed with sand paper 130 grit and then alcohol. I put 5 min epoxy on the white sticky pads and none of them held Ideas?
Old 02-26-2011 | 04:46 AM
  #915
damunoz32's Avatar
Try removing the adhesive pads and gluing straight onto the plastic.
Old 02-26-2011 | 04:48 AM
  #916
debsJK's Avatar
When you use the sandpaper are you just scuffing it or taking a bunch off?
  #917
damunoz32's Avatar
I didn't use sandpaper, but I'd assume just scuff it up.
Old 02-26-2011 | 02:29 PM
  #918
Rockroaster's Avatar
That's how I just did mine. Working on painting what I will be using in mine. Should have some pics tomorrow
Old 02-26-2011 | 04:44 PM
  #919
OH9JK's Avatar
JK-Forum Ambassador
Grill mod installed today. I picked up a screen door pet guard from the Home Depot on clearance rack. Total cost about $15.00 including paint and tie wraps.
Name:	JK grill mod.jpg
Old 02-26-2011 | 08:04 PM
  #920
RAINSTATEBEAR's Avatar
[QUOTE=DBB888;42472]I ordered mine through www.mcmaster.com
type in sheet metal
Click "Sheet Metal Products:
Click "Sheets,Bars,Strip, Cubes"
Thats for the sheet- 28.5x14
Part # 7582K12 for the zip tie cubes in black
Have grill ready
What part number did you order for your metal?
Quick Reply: Grill Mod
