Grill Mod
#771
i really like this idea, i might do this, I really hate the Mopar Chrome grill inserts i got a few days after i got my Jeep, but now i just hate them, I'm only keeping them on until i get a lift or something that makes my rig different then others.
#773
Summer Heat
I did the grill mod using the "Lowes Gutter Guard Method"... cheap and good looking. But this is the first time in three years I've noticed the jeep running hotter and sometimes the electric fan boost kicks in... hum.
#774
If this is the same question as has been asked many other times before, all you gotta do is soak them in water (or goof-off or other sticker remover), get the white backing material off of them, dry them off, scuff them up, and glue them onto the backside of the grill. Don't expect the self-adhesive paper junk on the holders to do the job.
I guess search is my friend... I will definitely be looking into that!
#775
No worries, I didn't mean to sound like an ass. You can probably just soak the white backing off the ones that have come loose, and deal with any other stragglers later if/when they get loose themselves... it's still a great mod for the appearance/function per dollar spent & time invested.
#777
#780
I used the following from McMaster:
http://www.mcmaster.com/#92725t22/=8h3774
Item # 92725T22
Desc: Hexagon-Hole Perforated Sheet .030Thk, 22 GA Steel, 1/4" Dia, 79% Open Area, 36" X 40"
This the above grill, it made 3 full grills. I would prefer Stainless Steel!
htp://www.mcmaster.com/#7582k22/=8h3baw
Item # 7582K22
Desc: UV-Resistant Cable Tie Holder Adhesive Back/Screw Mnt, 4-Way, for.18" Max Tie, Black
The only bad part about the above is that the actual physical size of the adhesive back mounts did fit between the center lines, or webs, so I had to machine them in half.. So if ordering the above cable tie holders, order half the size. PM me and I can find the right size to work.
I also used the following to glue:
Grainger.com
htp://www.grainger.com/Grainger/GORILLA-GLUE-Super-Glue-4GZK6?Pid=search
Grainger Item # 4GZK6
Desc: Super Glue, Bottle, 15g, Coverage 1 Square Inch per Drop, Temp. Range -65 to 220 F, Clamping Time 30 to 60 Sec, Full Cure 24 Hrs, For Instant Bonding With No Clamping, Indoor Use, Use On Wood, Plastic, Glass, Metal, Ceramics, Stone, Brick, Paper, Rubber, Polyurethane Adhesive, Rubber Toughened, Impact Resistant, Anti-Clog Tip
I used this on the back of the Cable Tie Holder Adhesive Back holders..
The paint I used was High Temperature Gloss Black from Home Depot.
Item # 92725T22
Item # 7582K22
Grainger.com
