Grill Mod
Old 08-14-2010 | 05:20 PM
  #761
Drsalee's Avatar
Great. More stuff that I need that I didn't even know existed 5 minutes ago!
Old 08-15-2010 | 10:17 AM
  #762
Ride_My_Jeep's Avatar
Finally had a chance to do mine today came out easier that I thought
quick run down
parts needed
1/ 150 grit sandpaper (freebie)
1/ 5 Min Epoxy (5 bucks)
3 / Sqaure Blocks (Buck and change a piece)
* / Zippie ties (freebie)
1/ Duplicolor etching Primer ( 5 Bucks)
1/ Duplicolor textured Metal ( 7 but paid 5 for it.. Told cashier I found it on clearance)
2/ Expanded sheet Metal ( 10 bucks a Piece)
OK , remove grill we know that and everything else pictured
Parts Used
Rough up inside of grill with sandpaper
Apply zip tie Blocks... The zip tied blocks stuck on pretty well, but backed it with the epoxy as a percaution
Primed and painted The Shests.. I didnt want to do black or silver for this so I went with the textured metal look... I think It came out pretty well 2 Coated Per can
Deciding which way to place the sheets..Horizontal Or Vertical
Chose the Horizontal look and Put the grill back in place
What Do you guys think?
Alfy
Old 08-15-2010 | 01:22 PM
  #763
PainKiller's Avatar
Looks bad ass
Old 08-15-2010 | 03:54 PM
  #764
jeepsta's Avatar
Default Thanks
Just did to my jeep looks great and really cheap!!!
Old 08-16-2010 | 08:42 PM
  #765
spleify's Avatar
This is a great mod! I plan on doing this soon.
Thanks for sharing
Old 08-17-2010 | 07:43 PM
  #766
dukedar's Avatar
Thumbs down Problem
Anyone have an issue with the tie wrap holders coming unstuck?
All of mine in the middle came unstuck, so I took it off for now.
Old 08-17-2010 | 07:50 PM
  #767
ntropy's Avatar
If this is the same question as has been asked many other times before, all you gotta do is soak them in water (or goof-off or other sticker remover), get the white backing material off of them, dry them off, scuff them up, and glue them onto the backside of the grill. Don't expect the self-adhesive paper junk on the holders to do the job.
Old 08-17-2010 | 08:11 PM
  #768
fadeout's Avatar
Gorilla Glue!!!!! ftw...
Old 08-17-2010 | 08:14 PM
  #769
Incognito's Avatar
Yep, I was lazy and didn't use Gorilla Glue, even though I bought some specifically for that purpose. Mines coming apart in the middle too
Old 08-17-2010 | 09:07 PM
  #770
rickyj's Avatar
The other option, if you just want to avoid the glue and problems with that all together is to just cut and form the insert around the radiator. The grill holds the insert against the radiator supports on the top and bottom with pressure, no movement, no worries, and you can remove it when you want. Already came in handy for me when I decided to change the color to blue, with reflective glass bead paint.
I don't think it is beyond most peoples skill level if you have patience and cutters.
Quick Reply: Grill Mod
