Grill Mod
#762
Finally had a chance to do mine today came out easier that I thought
quick run down
parts needed
1/ 150 grit sandpaper (freebie)
1/ 5 Min Epoxy (5 bucks)
3 / Sqaure Blocks (Buck and change a piece)
* / Zippie ties (freebie)
1/ Duplicolor etching Primer ( 5 Bucks)
1/ Duplicolor textured Metal ( 7 but paid 5 for it.. Told cashier I found it on clearance)
2/ Expanded sheet Metal ( 10 bucks a Piece)
OK , remove grill we know that and everything else pictured
Parts Used
Rough up inside of grill with sandpaper
Apply zip tie Blocks... The zip tied blocks stuck on pretty well, but backed it with the epoxy as a percaution
Primed and painted The Shests.. I didnt want to do black or silver for this so I went with the textured metal look... I think It came out pretty well 2 Coated Per can
Deciding which way to place the sheets..Horizontal Or Vertical
Chose the Horizontal look and Put the grill back in place
What Do you guys think?
Alfy
quick run down
parts needed
Parts Used
Alfy
#767
If this is the same question as has been asked many other times before, all you gotta do is soak them in water (or goof-off or other sticker remover), get the white backing material off of them, dry them off, scuff them up, and glue them onto the backside of the grill. Don't expect the self-adhesive paper junk on the holders to do the job.
#770
I don't think it is beyond most peoples skill level if you have patience and cutters.
