Grill Mod
Old 06-29-2009 | 01:39 AM
  #491
spydey's Avatar
Originally Posted by tuber
I purchased perforated stainless steel for my grill from h ttp://www.metalsupermarkets.com
They have stores in many locations across Canada and the U.S. The sheet cost me about $25 CDN
Installed it last fall, a week after I took delivery, and the stainless looks as good now as it did then.
Best looking one I've seen yet. Stainless is tops
Old 06-29-2009 | 05:58 PM
  #492
Sarbatche's Avatar
Originally Posted by phillips_kl
FYI, the sheet that you are using is cutting off a TON of air flow. It needs to have a higher % opened than what you have. Dont know how temps get in Guam, but here that would cause an engine to overheat not getting enough air flow. Check out McMaster-Carr and order some with a high opening amount.
I was concerned about this as well, and have been monitoring the engine temperature since I installed the mod. However, there has been no change in the reading on the temperature gauge.
I did have a problem with the ziptie sticky blocks adhering the inside of the grill, even though I prepped the area before putting them in place. This weekend I will remove the blocks and apply gorilla glue so it will stay in place better.
Old 06-29-2009 | 05:59 PM
  #493
Sarbatche's Avatar
Originally Posted by Robicon
Here it is done... I just wish i did the grill over in bedliner while it was off!! Thats my next project
I love the way it turned out
I'm liking the colored Jeep symbol!!!
Old 06-29-2009 | 06:13 PM
  #494
Robicon's Avatar
Thanks!! I plan on taking it all off to do the grill itself in bedliner spray then putting the red grill and red Jeep symbol back on.
Eventually will get the decals re-done with same Red and instead of Rubicon it will say "Robicon". "Wrangler" will go red as well Plus a custom designed decal once it's finished
Old 06-29-2009 | 06:19 PM
  #495
thx i did mine 2 days ago i used screen door dog protectors its is expanded aluminum with lots of air flow but smal enoughto keep out bugs thx
Old 06-30-2009 | 02:53 PM
  #496
jpelliott10's Avatar
Default Finished grill mod
Finished grill mod. Went with the plastic gutter mesh, spray painted it silver. Gorilla glued the cable tie mounts. Total cost less than $10
Old 06-30-2009 | 04:31 PM
  #497
Robicon's Avatar
Ok i think i might get blocked from this thread, but heres my bedlined grill with the red grill mod, doing more clear coat on the "Jeep" badge and will be on by the weekend!!
- Have a Happy Canada Day Tomorrow!!
Old 07-01-2009 | 11:26 PM
  #498
phillips_kl's Avatar
You may not notice the temp on the OE gauge. The issue may be in the engine and computer system. The lack of air is going to cause the thermostat to activate faster and more often than normal. Looks good, just use caution with that little of air flow.
Old 07-02-2009 | 08:10 AM
  #499
waikoah's Avatar
great grills! I will look into it if I keep my Jeep.
Old 07-02-2009 | 01:16 PM
  #500
pookie's Avatar
Thanks for the write up. I just did mine today. It took about 2 hours. Feeding the zip ties through took me forever.
Quick Reply: Grill Mod
