Grill Mod
Old 10-13-2008 | 09:16 AM
  #371
mcgoo656's Avatar
Default Re
Originally Posted by mcgoo656
I'm using Mcmaster Carr part #9344T51. Its a 20 gua. aluminum panel with 1/4" x 1/2" diamond pattern in it, its considered a "decorative" panel. Be sure to check out he other patterns they have as well.
The 20 gua. cuts really easy with tin snips, wont rust, and bends easily too if you want to use the non zip tie method.
Anybody have any pics of the other patterns (other than diamonds) used?
I have enough material left over for either method. Email me.
Installed mine yesterday after scuffing, prime, and paint. Looks great, awesome cheap mod. Will post pics soon.
Old 10-13-2008 | 09:24 AM
  #372
JKid's Avatar
Sponsoring Vendor
Epic-Addictions Representative
Originally Posted by vgullotta
Also, where are you all finding this good mesh material? I went to Home Depot, Lowes and OSH and none of them seemed to have the right stuff. I ended up using one of those reinforcing pieces from a screen door to keep pets from running through the door lol
gutter guard! Almost all hardware stores have them. You just need to ask where it is, but many people on here have used screen door guards.
Old 10-13-2008 | 04:40 PM
  #373
sixt7gt350's Avatar
I'm in that camp.
The screen door guards are typically thicker material than gutter covers.
Old 10-13-2008 | 09:53 PM
  #374
jkMatt's Avatar
Which Sheet metal did you use? I can't find a 28.5"?
Originally Posted by DBB888
I ordered mine through www.mcmaster.com
type in sheet metal
Click "Sheet Metal Products:
Click "Sheets,Bars,Strip, Cubes"
Thats for the sheet- 28.5x14
Part # 7582K12 for the zip tie cubes in black
I used Brake cleaner to clean the grill and black caliper paint to paint it.
Paint first so its ready for install!!
I Took out the 6 plastic screw- did by hand - hint hint
Pulled gently by the blinker- not to hard now its still connected
Pulled red tab out FIRST- then pulled plug out
Pulled bottom out
Have grill ready
Laid all the tie downs - 3 going down and one on each top hole
Zip tied each one using a small screwdriver to help get the tie up
Re Install the grill and Vuala!!
THANKS Ponpeta!!!!!!
Old 10-14-2008 | 07:05 AM
  #375
jeepin08's Avatar
I just did mine last night with the stucco lathe metal from the home depot. Looks great and hopefully last I'll guess I'll have to wait and see.
Old 10-14-2008 | 08:49 AM
  #376
AlmightyCrash's Avatar
cool mod...im trying to decide between yellow and black.
Old 10-14-2008 | 01:31 PM
  #377
acelockco's Avatar
BLACK!!!!!!!!!!!!!!!
Yellow would not look too good I think. But it would be different.
I am waiting for the paint on mine to dry right now so I can get them installed.
Old 10-15-2008 | 12:18 PM
  #378
Kes's Avatar
Kes
This is an excellent, quick mod. Thanks.
Old 10-15-2008 | 02:40 PM
  #379
akonius's Avatar
Here's my "gutter guard" grill mod! The 4'x5' sheet of expanded metal only cost $9 at Home Depot, the Rustoleum glass black paint $8 and the zip ties and blocks about $10...
Total project took about 1 hour (including paint drying time) and cost less than $30 ...opposed to the $200+ they want on the net for these grille inserts!! I don't think it looks too bad and it will definitely protect the radiator from rocks and stuff.
Old 10-21-2008 | 08:27 AM
  #380
Kes's Avatar
Kes
This grill mod is really one of the cheapest and best of the "cheap mods".
Quick Reply: Grill Mod
