Grill Mod
Old 08-08-2007 | 09:39 AM
  #151
Major Ho's Avatar
Since this thread is alive again. I will recommend glueing the pads down as previously mentioned becuase I have quite of few of them that have popped off now. Since its such a PITA for me to get the grill off because of my bumper/winch I say head off the problem before hand.
Old 08-08-2007 | 02:02 PM
  #152
John L's Avatar
Originally Posted by SFD1248Unlimited
Hey guys and gals. I am just getting around to doing this mod and I have a question. On that gutter guard stuff that everyone is using Does it have a curve to it. I just got back from Lowe's and the only gutter guard was like someone said 3ft long in a pack of 6 but it had a huge curve to it. Am I looking at the right stuff or should I keep looking or order it from that web site that sells it?
Andrew
The plastic gutter guard I used was bought at Ace Hardware. It is 6" wide and came in a roll, 25 foot of it. This is what it looks like in the store, I bought the black plastic. If you get the aluminum, be aware primer and paint will not adhere to aluminum without anodizing, chemical filming, or a PAA process.
BTW, 4 months now with the aircraft sealer, those bases aren't even thinking about coming off.
Old 08-08-2007 | 06:11 PM
  #153
SFD1248's Avatar
Hey thanks that helps out alot. Can't wait to get mine done as soon as I get the parts
Andrew
Old 08-14-2007 | 03:32 AM
  #154
oZmonKey's Avatar
Has anyone done this mod using window screen?
The gutter guards I've seen comes in that roll, and since I already have some black screen rolled up in the garage, I might attempt this.
Old 08-14-2007 | 09:10 AM
  #155
SFD1248's Avatar
Put mine together last night let the gorilla glue dry overnight and got it all back in place this morning. Looks great and probably one of the cheapest mods to date beside the drilled mirrors. Thanks to the person that came up with the idea. I ended up ordering the black plastic that DB888 suggested. Thanks again
Andrew
Old 08-28-2007 | 03:17 PM
  #156
Sgt P's Avatar
Default my grill mod
Ok, its official.
This site has turned me into an obsessed tinkerer...
[IMG][/IMG]
used the cheap black plastic gutter screen from the "low" priced home improvement store
[IMG][/IMG]
I like that there is minimal material. Max air flow!
[IMG][/IMG]
I also used a small spot of (2-part) plastic super glue on each mounting base. I'm hoping that will help with the amount of heat those stickers must tolerate...
I love this site!
Old 08-28-2007 | 04:17 PM
  #157
BrinksJeep's Avatar
I used the mesh material from an expanded aluminum pet screen for a screen door. Perfect size with alittle trimming.
Bright unfinished aluminum, $20 at OSH. Used the zip tie cubes and alittle epoxy. It bends nicely to conform to the grill.
Old 08-30-2007 | 06:33 PM
  #158
SFD1248's Avatar
Here is mine. I was so happy with the way the look and ease of installment turned out.
Old 08-31-2007 | 04:43 AM
  #159
verbaltharhino's Avatar
SFD- What type of mesh did you use? Looks like good stuff. Nice and thin, plus the diamonds go in the right direction. I used plastic but would like to see if what you used is available locally. Thanks!
Old 09-08-2007 | 09:06 PM
  #160
JKid's Avatar
Sponsoring Vendor
Epic-Addictions Representative
hey i used 7 seperate pieces to put together my aluminum grille screen. ill post some pics tomorrow. i molded them around the shape of the back.
Quick Reply: Grill Mod
