Grill Mod
Old 04-14-2012 | 06:47 PM
  #1121
robsjeep9's Avatar
JK-Forum Ambassador
Originally Posted by Matthewd5
Is dremeling the zip tie squares a must do?
Matthew
Well guys who have just used the zip ties squares say they are coming off...... Just try and get the best glue/adhesive out there for plastic. So they stick properly and will last.... hopefully
Old 04-14-2012 | 07:27 PM
  #1122
GulfCoastJeeper's Avatar
True story^ sanded and cleaned mine before sticking zip tie blocks on and done are coming off
Old 04-14-2012 | 10:13 PM
  #1123
Delux2769's Avatar
I did mine about 4 months ago, and from all the road stuff and wind has made many of my inner ones fail.
I need to go back through and take off the sticky and glue down properly.
I would suggest glueing them down properly in the beginning.
Old 04-15-2012 | 03:29 AM
  #1124
DangerDan's Avatar
I removed the sticky adhesive as many have mentioned. I also used the gel type glue, but I'd comment that you need to use more then a dab in each corner. Several of the tabs came loose when I attached the zip ties, so I had some heavier glue adhesive and that fixed the issue (but took longer to dry).
Old 04-15-2012 | 03:47 AM
  #1125
robsjeep9's Avatar
JK-Forum Ambassador
Yeah I actualy used and epoxy type glue for plastic/pvc in behind and dropped gorilla glue on top also and let sit over night... with the zip ties already inserted(had to wiggle some loose the next day because of the glue bleeding but no biggie). Better then trying to feed all the zip ties thru after with glue clogging the holes. Looked a little messy but no one sees that side and I'm more worried about them not coming lose.
ID:	304297   Click image for larger version
Old 04-15-2012 | 06:48 AM
  #1126
Goose88's Avatar
Just finished mine last night... Only put a little dab of glue in a couple places
Old 04-15-2012 | 06:52 AM
  #1127
Matthewd5's Avatar
Originally Posted by Jdell68
Did mine last month with the aluminum sheet from HD. used the tie down squares, tie straps with contact cement so far holding on strong...
Attachment 304043 Attachment 304044
Getting ready to do this, what's a good way to remove adhesive without dremel?
Matthew
Old 04-15-2012 | 08:51 AM
  #1128
rizzo's Avatar
Default my grille mod
I vinyl wrapped my grille and did the DIY grille mod. I cleaned the grille with a non detergent grease and wax remover. Laid the vinyl out and worked the flat areas first. Then were there was a wrinkle I just lifted the vinyl and started from that area. Then with heat i pulled the vinyl over the edges. Then with heat formed the grille slots, then I cut out the slots. i did the same for the head light and signal light holes. I took the sticky backs off of the mounting bases. Then I sanded the bases and the grille where I was going to place the Bases. I used 60 sec. epoxy. Then I cut the Gutter guard to size and Zip tied them down. Easy and looks good.
ID:	304502   Click image for larger version
ID:	304503   Click image for larger version
ID:	304505   Click image for larger version
ID:	304506   Click image for larger version
Old 04-15-2012 | 11:25 AM
  #1129
JVDBogart's Avatar
Cool looking grill man!! Where did you get that camo vinyl wrap??
Old 04-15-2012 | 07:38 PM
  #1130
afpilot82's Avatar
Veteran: Air ForceJK-Forum Ambassador
Very unique, I like the digital camo!
Quick Reply: Grill Mod
