Extend Breather Hoses with Pictures - Axle & Transfer Case - 2012 Manual 2DR
#21
Auto Trans Breather
Hi Rooster
i've checked all the locations of breather hose today
i founded three of them, rear axle,front axle, tcase breather hose which is located on the surface of plastic engine cover but im not sure if it is tcase hose or auto transmission hose.
i can not find the auto transmission's breather hose
would you help me to find the auto transmission hose?
Good Luck
#23
There is a new River Raider "Smilin' Bobs" breather extension write-up to check out. It has a bunch of pictures and shows how you can run the breathers to the air-box.
LINK> https://www.jk-forum.com/forums/modi...7/#post3320835
I'm not sure. Over here at least, fuel line is so cheap that I would just use it. Then you don't have to worry about it.
#24
I found a great thread for extending the Manual Transmission Breather that's under the boot.
https://www.jk-forum.com/forums/jk-w...ite-up-261746/
#26
Breathe right
Thanks for the fantastic write-up. It gave me the confidence to do the axle breathers on my 2010 JKUS this morning.
I started with 10' of 5/16 fuel hose. Fuel hose is overkill. The original tube is 5/16 vacuum hose (no cord reinforcement) but the local AdvAuto was out so they sold me fuel hose for the same price.
I started with the rear. Removed old hose by unplugging from the axle then sliding the capped end of the hose (in fender) off the plastic screw. If you wiggle it, it will come off. Find where the metal clip attaches to the frame. You will want to clip the new hose in the same place. Then pull the hose out from under the fender so the metal clip stays on it. I transferred the metal clip to the new hose but since my Jeep is raised 4" I added 4" from the clip to the axle end of the hose. Next I un-taped the plastic holder at the cap end and reattached it with the same tape to the new hose the same distance from the metal clip as the old one. Re-clip the hose where it was and extend it into the passenger side tail light like Rooster showed above.
You can see the metal clip in the middle of this picture and the taped clip towards the top...
The hose passes above the frame cross member...
I added a plastic tie to the fame to help keep the longer hose in position...
Moving to the front... Once again, note where the two (2) existing metal clips are. They will be used on the new hose. I added 3" from the lower clip to the axle end for my added travel.
I routed the hose under the brake lines and electrical bundles over to the top of the fender. I could have gone to the firewall but I didn't want anything near the steering shaft.
(breather cap is white with green dot)
This was a fast and easy mod. The transfer case and autotrans will have to wait. I haven't found the ends yet.
#29
Thank you for the write up...
So you used 3/8" throughout?
This write up is great, I'm sure it will make more sense with my iPad with use under the Jeep!
Dumb question, my Jeep goes into the local 4x4 shop where they are swapping out both factory axels and replacing the whole assembly with Dynatrac pro rock d44 and pro rock d60, should I quiz my mechanics to see if their putting in longer lines while their doing the swap?
Matthew
Matthew
#30
Attachment 502783
Attachment 502784
Attachment 502785
Attachment 502786
Attachment 502787
Attachment 502783
Attachment 502784
Attachment 502785
Attachment 502786
Attachment 502787
Kind of like fishing av cables through walls/floors
Matthew
