Extend Breather Hoses with Pictures - Axle & Transfer Case - 2012 Manual 2DR
You are correct rooster about the breather under the engine cover being for the T-case as i have traced it when I extended all mine. The only thing I did different was I ran my rear breather the whole way up under the hood right beside the T-case breather.
Happened to of read the write up this morning... then later on had to run to Advance Auto for a pair of headlight bulbs; and couldn't help but pick up the parts I needed to do this while I was there.
Thanks for the great write up, heading out to the garage shortly to install!
Originally Posted by lkr05111
Thank you for your great writes up
I'm a Korean owner of 2.8CRD rubicon
i'm kindly asking you that all the breather's location also same?
If you need a backup set of headlights or haven't put those in yet, you can get some Philips X-treme Power +80 H13 9008 for $21 a pair after $10 rebate on Amazon (through halloween). They are a nice mild upgrade to the stock lights. Mostly in the whiter color and a bit more fill in front and to the side of the Jeep.
(and I apologize for the brief light bulb thread hijack)
The link doesn't show up on the "moble" amazon site for phones. It has a link right next to the price to "get forms." on the standard web desktop site. Heres the link to the rebate EDIT the link didn't work the first time (I think it might work now). If your having problems. If your on a phone see if you can pull up the desktop version, or use a laptop or desktop computer to see the link. The amazon page is "Philips H13 9008 X-treme Power Headlight Bulb, Pack of 2". Good Luck
i've checked all the locations of breather hose today
i founded three of them, rear axle,front axle, tcase breather hose which is located on the surface of plastic engine cover but im not sure if it is tcase hose or auto transmission hose.
i can not find the auto transmission's breather hose
would you help me to find the auto transmission hose?
