Drilled the side view mirrors!
Old 06-05-2011 | 06:45 AM
  #651
SQUEEKY CLEEN's Avatar
Originally Posted by dinojeep
I want to drill these holes but Im afraid the water wont drain because I know there is mud and small rocks in there! I might have to drill a big hole!
Had the same in my mirrors. I drilled a slightly bigger hole and flushed it good with some clean water. Worked great!
Old 07-08-2011 | 03:43 AM
  #652
Natedawggg54's Avatar
Originally Posted by spartacus_33
I was going nuts with these white drip lines. I'm a member on a detailing forum and was asking those guys on product recommendations for removing the mineral buildup. Pretty funny... but I was pointed back here for this solution.
Great Idea! I used a 1/8" bit.
I actually took my mirrors off to polish the doors with my Porter Cable 7424 and also to see what was inside the mirror. I took a pair of scissors and cut a small "V" in the bottom of gasket to ensure that the water would drain out.
what do u use for removing the mineral build up???
Old 07-08-2011 | 03:47 AM
  #653
Hskr4x4's Avatar
Claybar or a secret of the trade for any hard water spots is vinegar
Old 07-15-2011 | 05:02 PM
  #654
Mraab's Avatar
I did not see this stated before, so a heads up to 2011 owners. Don't bother drilling! I was going to drill my mirrors, but I decided to take one off since I have the heated mirrors and I wanted to take a look before I drill into any wires. I found that my mirrors already from the factory have a quarter inch section of the seal cut out the bottom and a v cut in with a spout that feeds it. I do get the drain marks and a white reside but it doesn't drain for days as others have reported.
Old 07-15-2011 | 06:07 PM
  #655
hacker's Avatar
Default 2011
Sprayed the mirrors on my 2011 and water slowly ran out of the bottom at the notch cut it the gasket at the factory. Drilled them anyways and they empty much quicker now.
Old 07-16-2011 | 03:10 AM
  #656
Mraab's Avatar
Hmm maybe I will deepen the v notch a little bit. And see how that works.
Old 07-19-2011 | 03:01 AM
  #657
Mraab's Avatar
Just an update on the 2011. I took off the mirrors again for a closer look at what the factory did, while there is a cut out in the seal and a V notch in the bottom, I made it a bit deeper with my trusty files. I filed the bottom and inside the mirrors. This is all but completely invisible to anyone not looking for it. When testing I found the stream is much steadier now.
Old 07-19-2011 | 01:53 PM
  #658
Aussie Jeepster's Avatar
Its good to have a steady stream!
Old 08-08-2011 | 05:05 PM
  #659
EMA's Avatar
EMA
When I took my mirrors off, I was shocked at what was behind that gasket - sand, bugs, dirt, and I'm guessing a lot of road salt. I took some pics of what it looked like but they didn't come out. Here is how I cut my gasket and where I drilled the extra whole. I now have a nice stream coming out of the new hole and out of the original weep hole.
Old 08-23-2011 | 01:05 PM
  #660
Wads13's Avatar
Originally Posted by Interstink
I previously owned a 2008 JK and after a wash, you will see water spots on the door and hinges below both mirrors. A lot of water... And you may continue to see more spots days after that bath. It continued for so many days I considered it magical. If I was ever stranded in the dessert with my JK, I could survive weeks with the amount of water those mirrors held.
After you drill the holes in the mirrors, problem solved.
Problem solved if you're not in the desert (i.e.: No more secret Jeep survival tactic). JK... This looks like a helpful mod!
Quick Reply: Drilled the side view mirrors!
