Drilled the side view mirrors!
Old 05-17-2011 | 06:39 PM
  #641
JK-jeepit's Avatar
2011 still has it.... just did the mod...... hopefully no more water stains down the door....
thanks to the op
Old 05-18-2011 | 08:05 PM
  #642
Sierra141's Avatar
Just did mine, bunch of sand came out of mine!
Old 05-23-2011 | 11:55 AM
  #643
BLK08JK's Avatar
Default water stains
So the previous owner of my JK didn't do this mod and I have old water marks visible that I can't get rid of. Does anyone have a fix for getting these 'permanent' marks off my doors? Also, after drilling holes myself and taking the hose to it, water doesn't come out the hole but instead leaks out behind the circular plastic... fail.
Old 05-23-2011 | 11:58 AM
  #644
Shankspony's Avatar
Originally Posted by BLK08JK
So the previous owner of my JK didn't do this mod and I have old water marks visible that I can't get rid of. Does anyone have a fix for getting this 'permanent' marks off my doors? Also, after drilling holes myself and taking the hose to it, water doesn't come out the hole but instead leaks out behind the circular plastic... fail.
You can try a polish like NuFinish or go hippie style and try the clay brick thing. My only suggestions. I would NOT do CLR (if it came to mind) as it has acids that will trash your finish.
Old 05-23-2011 | 12:02 PM
  #645
BLK08JK's Avatar
CLR did come to mind but thought it might do bad things, thanks for confirming. I thought about the claybar stuff... never used before but will give it a go!
Old 05-23-2011 | 12:04 PM
  #646
Shankspony's Avatar
Now that I think about it... The claybar is more for stuff stuck to the surface (like sap) rather than impregnated in the finish. Might want to try that second. I've never used the claybar method though.
Old 05-23-2011 | 12:16 PM
  #647
BLK08JK's Avatar
Originally Posted by jeepmojo
light compound or even maquires scratch remover might remove those stains id bet , gotta drill mine when i get a chance
Can you give a name of some 'light compound'? Not quite sure what you mean...
For NuFinish, were you thinking the polish or the scratch remover?
Old 05-23-2011 | 12:20 PM
  #648
Shankspony's Avatar
I had the Polish in mind.
Old 05-31-2011 | 04:46 PM
  #649
bmidd31's Avatar
2011 here and there was water in mine after a wash...
Old 06-04-2011 | 09:46 PM
  #650
dinojeep's Avatar
I want to drill these holes but Im afraid the water wont drain because I know there is mud and small rocks in there! I might have to drill a big hole!
Quick Reply: Drilled the side view mirrors!
