Drilled the side view mirrors!
Old 12-18-2009 | 04:58 AM
  #541
acidsnow's Avatar
drilled the 2010 last nite, got a bit of water, only got a teaspoon of water after a couple of high pressure washes. I took the passenger side off to drill eaiser, and found the inside already starting to build a white corroision.
Old 12-22-2009 | 12:22 PM
  #542
JKBANDIT55's Avatar
after it rains or i wash my jeep, I notice that water a leak from the mirrirs at least for a day or two!!!
Old 02-14-2010 | 01:41 PM
  #543
TheQuiet1's Avatar
Thought I would Bump this thread. It's a great idea and works like a charm!
Old 02-15-2010 | 08:32 PM
  #544
Summit Jeep's Avatar
Thumbs down
Old 02-17-2010 | 11:37 AM
  #545
TheQuiet1's Avatar
Thumbs up
Worked for me. I had the dripping for several hours after a run through the car wash, mainly the brushless/touchless ones with high pressure water jets. I pulled the drivers side mirror off to have a look and as soon as the bolts were loosened the water just dumped out. Drilled a small hole in each mirror bracket and now... no more water building up in there
Old 02-17-2010 | 12:37 PM
  #546
quadidaho's Avatar
Did it last night- -didn't pull the mirrors just went slow and easy with the drill. Worked like a champ----what an easy fix for a PITA problem.
Old 02-17-2010 | 07:45 PM
  #547
mmacJK's Avatar
Well
At first I was totally confused... not ratchets... not air tools and no swearing... I was genuinely sure I didnt know how to use a drill anymore after bumpers, winches, lifts and tires...
Somehow, i didnt f*k it up and was extremely confused that i didnt have to put something on and take it off 2 more times to figure out exactly how it worked.
Awesome!
Old 02-17-2010 | 08:05 PM
  #548
Dylanjam77's Avatar
Originally Posted by Summit Jeep
Wow Summit.... ALL you do is disagree with everyone's posts. A quick review of your previous post shows that a HUGE amount of your 31 previous post are some negative type response and usually in just some stupid emoticon type reply.
Hey this just in, if you don't like it just Go away...
Old 02-18-2010 | 05:52 PM
  #549
ZoSo-Green's Avatar
I did it.
I could not believe how much muck ran out before it cleared up.
Now, when I wash, its done drippin' by the time I'm done drying.
Old 03-03-2010 | 02:27 PM
  #550
Bad_CRC's Avatar
I want to do this if it really works like people are saying, but I don't want water to start pouring out as I'm holding an electric drill.
Quick Reply: Drilled the side view mirrors!
