Drilled the side view mirrors!
#541
drilled the 2010 last nite, got a bit of water, only got a teaspoon of water after a couple of high pressure washes. I took the passenger side off to drill eaiser, and found the inside already starting to build a white corroision.
#545
Worked for me. I had the dripping for several hours after a run through the car wash, mainly the brushless/touchless ones with high pressure water jets. I pulled the drivers side mirror off to have a look and as soon as the bolts were loosened the water just dumped out. Drilled a small hole in each mirror bracket and now... no more water building up in there
#547
Well
At first I was totally confused... not ratchets... not air tools and no swearing... I was genuinely sure I didnt know how to use a drill anymore after bumpers, winches, lifts and tires...
Somehow, i didnt f*k it up and was extremely confused that i didnt have to put something on and take it off 2 more times to figure out exactly how it worked.
Awesome!
Awesome!
#548
Wow Summit.... ALL you do is disagree with everyone's posts. A quick review of your previous post shows that a HUGE amount of your 31 previous post are some negative type response and usually in just some stupid emoticon type reply.
Hey this just in, if you don't like it just Go away...
