Drilled the side view mirrors!
Old 06-16-2009 | 03:53 AM
  #471
Mk-Dubai's Avatar
Guys i really need this mod, cuz the mirror pee is killing me
can someone post a pic of where exactly to drill
thanks again
Old 06-16-2009 | 04:47 PM
  #472
phillips_kl's Avatar
thanks again
about 1/4 inch from the bottom of the mirror mount. drill at a slight angle. oh, take th mirrors off j-i-c
Old 06-16-2009 | 04:55 PM
  #473
Fermin's Avatar
thanks again
Old 06-16-2009 | 06:39 PM
  #474
adamisadam's Avatar
Here's mine:
Old 06-17-2009 | 04:43 AM
  #475
Mk-Dubai's Avatar
Originally Posted by adamisadam
Here's mine:
thanks alot guys.
Now if i can just figure out how to get these damn mirrors of ill be drilling away.
Old 06-17-2009 | 10:34 AM
  #476
adamisadam's Avatar
thanks alot guys.
How to get them off? Umm, open the door and unscrew the torx screws on the inside. Extremely easy.
Old 06-18-2009 | 01:49 AM
  #477
thanks alot guys.
Open the window, reach through, and use a T-40 to remove the bolts (hold the mirror so that it doesnt end up on the ground)
Old 06-18-2009 | 02:04 AM
  #478
Mk-Dubai's Avatar
Thanks aLot guys youv been a big help.
Old 06-18-2009 | 06:43 AM
  #479
db09JKU's Avatar
Originally Posted by phillips_kl
Even though the '09s have the notch, the foam covers it and there was that white build-up from the oxidized aluminium. Drilled and removed a little foam.
I made the notch a little bigger and cut out some of the foam, but it still pee's a little, just a dribble. I need and will go back and drill them....sounds like something to do this weekend.
Old 06-19-2009 | 06:58 AM
  #480
TRAILBUCK's Avatar
I made the factory notch on my mirrors bigger & trimmed the foam sealer around it also. I like that look better than the drilled hole. It works great for me! No continues water draining.
Quick Reply: Drilled the side view mirrors!
