Disable/Enable feature codes/sequences
Old 04-30-2012, 11:24 AM
  #61
arcoleman's Avatar
Originally Posted by zeppo
2010 users manual page 20:
The system can be programmed to unlock all the doors
upon the first RKE transmitter UNLOCK button press,
using the following procedure:
1. Press and hold the LOCK button on a programmed
RKE transmitter.
2. Continue to hold the RKE transmitter LOCK button
for at least four seconds, but not longer than 10 seconds,
then press and hold the RKE transmitter UNLOCK
button.
3. Release both buttons at the same time.
4. Test this feature while outside of the vehicle, by
pressing the LOCK/UNLOCK button on the RKE transmitter.
NOTE: Pressing the RKE transmitter LOCK button
while you are inside of the vehicle will activate the
Vehicle Security Alarm. Opening a door with the Vehicle
Security Alarm activated will cause the alarm to sound.
Press the RKE transmitter UNLOCK button to deactivate
the Vehicle Security Alarm.
5. If the desired programming was not achieved or to
reactivate this feature, repeat the above steps.
Did this on my 2007, works great
Old 04-30-2012, 02:01 PM
  #62
Johnny_t's Avatar
Awesome info. Got some new stuff to tinker with. Thanks. Subscribed
Old 04-30-2012, 04:07 PM
  #63
FlameRedJK's Avatar
Originally Posted by SilverJK12
Good info!!! What about up, down, up ,down ,left ,right, left, right, ,B, A ,select , start.
(old school nintendo Contra code for those not getting it ) lol.
haha gotta love the Konami code...Only way I could ever beat Contra...
Old 05-02-2012, 06:42 PM
  #64
firejeep508's Avatar
Originally Posted by DanieltheManual
Hill start assist disable proceedure
copy and pasted from manual
HSA Off
If you wish to turn off the HSA system, follow this procedure:
1. Start with the engine off and vehicle in PARK (automatic transmission) or NEUTRAL with clutch out (manual transmission) with wheels straight. Apply parking brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the clutch out, rotate the steering wheel 180° counterclockwise from center.
4. Press the ESP OFF switch four times within twenty seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESP/ TCS Indicator Light” will blink several times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off HSA. Repeat steps 1-7 to re-enable HSA functionality.
cheers
I've been wondering how to get that freaking hill assist to turn off. It drives me NUTS! Thanks!
Old 05-02-2012, 06:56 PM
  #65
cousincleatus's Avatar
Got the ESP turned off its actually fun on dirt roads again great thread
Old 05-02-2012, 06:57 PM
  #66
jkrubcon's Avatar
Does your cruise still work?
Old 05-02-2012, 07:14 PM
  #67
Yup everything still works and I can slide it around corners do a donut and its just fun to drive
Old 05-02-2012, 07:18 PM
  #68
jkrubcon's Avatar
What year is your jeep?
Old 05-02-2012, 08:12 PM
  #69
2010 4-door the light on the dash stays lit but I can live with that
Old 05-02-2012, 08:26 PM
  #70
joe002's Avatar
Originally Posted by Freewill
... see the dealer. They can change it...
I took mine into my dealer and they didn't know how to do it.
Quick Reply: Disable/Enable feature codes/sequences
