Disable/Enable feature codes/sequences
#41
Hill start assist disable proceedure
copy and pasted from manual
HSA Off
If you wish to turn off the HSA system, follow this procedure:
1. Start with the engine off and vehicle in PARK (automatic transmission) or NEUTRAL with clutch out (manual transmission) with wheels straight. Apply parking brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the clutch out, rotate the steering wheel 180° counterclockwise from center.
4. Press the ESP OFF switch four times within twenty seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESP/ TCS Indicator Light” will blink several times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off HSA. Repeat steps 1-7 to re-enable HSA functionality.
cheers
HSA Off
cheers
I put 007-373-5963 into the Jeep and Mike Tyson jumped out and started beating up on it, luckily I used the contra code first so my Jeep has 30 lives.
#42
To turn off the lights flash when locking
Press the unlock button on the fob for 4 to 10 seconds. While still holding the unlock button press and hold the lock button. Release both and test.
#43
Stop the "HONK"
Stop the "HONK" when you lock the doors using the fob.
Press and hold the Lock button on the fob for at least 5 seconds, while still holding the lock button press the Panic button and release both. Test operation.
#45
#48
Great thread. No longer have the HONK and all doors open with one click. Still have the flash from the marker lights (which I like) but would love to get rid of the headlights turning on everytime I unlock.
#49
If you have the Connectivity Group with Electronic Vehicle Information Center (EVIC), see the owners manual to learn how to keep the headlights off when unlocking.
Or, without EVIC, see the dealer. They can change it.
I got mine done by the dealer when the JK went in for a recall reflash. Told them it had been set to "headlights off" when I bought the Jeep and asked them make sure it was still off after the reflash.
