Disable/Enable feature codes/sequences
Old 02-28-2014, 05:38 AM
  #251
blakeX84's Avatar
That autolock disable feature is awesome. Man that was getting annoying!
Old 03-04-2014, 09:44 AM
  #252
ajh818's Avatar
I saw a lot of you post how to turn off esp for good but if you shift in 4 hi and hold the traction control it turns it off until you shift back into 2wd. Or at least that's how my 2013 jku works
Old 03-25-2014, 06:20 PM
  #253
ChaoticJK's Avatar
Originally Posted by SaFFFari
All useful info! :-) I bought a pre-owned JK, and never got the owners manual, so JK-forums is the next best thing if not better
You can download it to your computer...IGM Google it and look for one that's a PDF.https://www.jk-forum.com/forums/imag...es/beermug.gif
Old 03-11-2015, 12:36 PM
  #254
pluskoca's Avatar
Default NO ESP Button
Originally Posted by DanieltheManual
Hill start assist disable proceedure
copy and pasted from manual
HSA Off
If you wish to turn off the HSA system, follow this procedure:
1. Start with the engine off and vehicle in PARK (automatic transmission) or NEUTRAL with clutch out (manual transmission) with wheels straight. Apply parking brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the clutch out, rotate the steering wheel 180° counterclockwise from center.
4. Press the ESP OFF switch four times within twenty seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESP/ TCS Indicator Light” will blink several times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off HSA. Repeat steps 1-7 to re-enable HSA functionality.
cheers
My 2012 JK 6 speed manual does not have an ESP off button. I only have the Limited Slip and Hazard buttons. How do i go about turning off HSA w/out this button?
Old 03-11-2015, 04:05 PM
  #255
patmasterflash's Avatar
Wouldn't this only apply to automatics? Maybe that's why you don't have it.
Old 03-12-2015, 07:29 AM
  #256
DJR
DJR's Avatar
No - I have a 2015 manual and it worked for me. I remember a different method that didn't involve hitting that button on my 2011. Maybe it's the same for the 2012 as it was for the 2011?
Old 03-16-2015, 11:55 AM
  #257
Dirtymoney's Avatar
Originally Posted by soberbyker
Yea yea, a couple of old posts, if you guys are still around .... The audible alarm can be turned off by the dealer for the dog in the front seat thing., the dash light would still light up though. One way to get rid of both, seat belt extenders, the system just wants something plugged in
I have been told that these types of items (shown below) are popular in asian countries.
The sole reason for them seems to be to stop the seatbelt ding. I see these all over the websites that sell cheap products from china.
Old 04-22-2015, 03:22 PM
  #258
terpsmandan's Avatar
Wondering if anyone in JK land has written any JK PIDs for the Torque App. There is a whole PID list for the Prius that lets you reset lots of things with the App, seat belt chimes, back up alarm, etc.
Old 05-07-2015, 09:34 PM
  #259
Sandypants's Avatar
Any write ups on moding the e brake so DVD and navigation work in motion?
Old 05-08-2015, 04:13 AM
  #260
Wrangler428's Avatar
You have to use what is called a mygig lockpick. They aren't cheap but they do work well. I have had mine in for a couple of years and never had a problem. Just upgraded my whole system so I don't need to use it now.
Quick Reply: Disable/Enable feature codes/sequences
