Disable/Enable feature codes/sequences
Old 12-05-2012, 03:45 PM
  #191
Keck27's Avatar
Anyone no how to get all four doors to auto unlock once you turn off your jeep. The driver side of my 07 JKU will unlock and ill walk around to get my boy out and ... Dang it the door is still locked. Pain in the REAR. Any help would be great. Thx
Old 12-05-2012, 04:04 PM
  #192
Cobb_Sahara's Avatar
Push up on the unlock button.... J/k. Mine unlocks all the doors as soon as a pull the door handle.
Old 12-05-2012, 05:28 PM
  #193
Wrangler428's Avatar
Had the same problem. Found it in the manual, I can't remember exactly but I think it is turn key to the on and off position 5 times and then hold the lock button to unlock. You should hear a tone to let you know the programming has been completed. Took me a few tries but it finally worked. Check the manual to be sure. Hope this helps a little.
Old 12-05-2012, 06:15 PM
  #194
Keck27's Avatar
Good deal. I'll check it out. Thx
Old 12-10-2012, 05:50 AM
  #195
SAR JK's Avatar
Try this...
Set the locks to auto-lock at 15 mph and auto unlock all when either front door is opened.
Get in the Jeep, insert the key. Cycle the key from insertion position to "on" position 5 times, upon completing the 5th cycle make sure the key ends in the "on" position, press the unlock switch up twice.
Old 12-11-2012, 06:23 PM
  #196
Keck27's Avatar
Originally Posted by SAR JK
Try this...
Ok so on the 5th cycle it should be in the on position and then hit the unlock button twice...? I will try this tomorrow night. Will I hear any "ding" or sound or do u know?
Old 12-12-2012, 04:56 AM
  #197
the_cuse420's Avatar
Originally Posted by Powderburn
I have a newer 08, Got it in oct of 07 and i killed the ESP on the 2nd try! So glad its gone!!! Donuts, here i come!
When it is done properly will the esp light stay on??? I need to know
Old 12-12-2012, 04:58 AM
  #198
Browny10783's Avatar
awesome thread
Old 12-13-2012, 06:15 PM
  #199
Jmcnamara74's Avatar
This is the best thread yet. I really dislike the manual on disc. Thanks for all of the help.
Old 12-14-2012, 02:49 PM
  #200
Jeeps_and_Boats's Avatar
Great thread... I know some things to do to the 2013 when it gets here.
Is it just me, or do a lot of you drive about without your seat belts on? #tisk-tisk
Quick Reply: Disable/Enable feature codes/sequences
