Disable/Enable feature codes/sequences
#191
Anyone no how to get all four doors to auto unlock once you turn off your jeep. The driver side of my 07 JKU will unlock and ill walk around to get my boy out and ... Dang it the door is still locked. Pain in the REAR. Any help would be great. Thx
#192
Push up on the unlock button.... J/k. Mine unlocks all the doors as soon as a pull the door handle.
#193
Had the same problem. Found it in the manual, I can't remember exactly but I think it is turn key to the on and off position 5 times and then hold the lock button to unlock. You should hear a tone to let you know the programming has been completed. Took me a few tries but it finally worked. Check the manual to be sure. Hope this helps a little.
#194
#195
Try this...
Set the locks to auto-lock at 15 mph and auto unlock all when either front door is opened.
Get in the Jeep, insert the key. Cycle the key from insertion position to "on" position 5 times, upon completing the 5th cycle make sure the key ends in the "on" position, press the unlock switch up twice.
#196
Try this...
#197
