Disable/Enable feature codes/sequences
#166
Steering wheel really needs to be centered anyway so you might as well center it and then try the disable dance again. Lots of threads here about how to center the wheel. Takes one wrench and 10 minutes.
#167
Re: Disable/Enable feature codes/sequences * Stop Door Ding
All I do is unplug the wire leaving the strap connected so I don't accidenitly push the door open too wide. I don't move the red locking pin to the left when it's plugging it; I leave it in the right (remove) position all the time; never had it come unplugged.
#168
When you want to close the door, just release the latch with the door handle same as you would if the door were closed. If you forget to release the latch and try to close the door it will just thunk instead of latching to remind you. No harm done.
This works like a charm and doesn't require anything but a screwdriver or similar tool.
#170
