Disable/Enable feature codes/sequences
Old 07-27-2012, 10:08 AM
  #161
TYDFAN's Avatar
Originally Posted by Mcgee149
I can do alot of this from my wheel with the options on the dash
This is for the older models.
-Nathan
Old 07-31-2012, 06:40 AM
  #162
DeucesALLin's Avatar
Default I think...
... Because my steering wheel is uncentered I am not able to do this? I tried it most of Friday morning.
Old 07-31-2012, 03:45 PM
  #163
Bubbacon's Avatar
Originally Posted by MikeO
how do you do this with an 08?
Worked perfectly on my '11
Old 07-31-2012, 09:02 PM
  #164
MikeO's Avatar
still cant get it to work
Old 08-02-2012, 11:21 AM
  #165
Freewill's Avatar
-Nathan
Actually its for models without connectivity group regardless of age.
Old 08-02-2012, 11:23 AM
  #166
Freewill's Avatar
Steering wheel really needs to be centered anyway so you might as well center it and then try the disable dance again. Lots of threads here about how to center the wheel. Takes one wrench and 10 minutes.
Old 08-02-2012, 12:56 PM
  #167
paulp575's Avatar
Default Re: Disable/Enable feature codes/sequences * Stop Door Ding
Originally Posted by Rebelliousw0n
Has anyone figured out how to do this yet? Other than unplugging the door. I like to use the radio when working out in the field but the ding gets irritating.
All I do is unplug the wire leaving the strap connected so I don't accidenitly push the door open too wide. I don't move the red locking pin to the left when it's plugging it; I leave it in the right (remove) position all the time; never had it come unplugged.
Old 08-03-2012, 09:09 AM
  #168
Freewill's Avatar
There's an opening on the edge of the door where the latch is exposed. Take a screwdriver and trip the latch while the door is open. Just use the screwdriver to do what the striker would do if you closed the door against the door post. That will trip the switch and make the system think the door is closed. No chime!
When you want to close the door, just release the latch with the door handle same as you would if the door were closed. If you forget to release the latch and try to close the door it will just thunk instead of latching to remind you. No harm done.
This works like a charm and doesn't require anything but a screwdriver or similar tool.
Old 08-08-2012, 08:16 AM
  #169
MikeO's Avatar
yup it's official... can't get all doors to unlock at the first click. code doesn't work
Old 08-08-2012, 12:56 PM
  #170
BIGag's Avatar
The. You've done something wrong did this over a year ago and still wrks try agin u maybe have held too long
Quick Reply: Disable/Enable feature codes/sequences
