Disable/Enable feature codes/sequences
Old 05-28-2012, 09:36 AM
  #111
BlueBennett's Avatar
Ok thanks, I'll try the download.
Old 05-30-2012, 03:23 PM
  #112
Cozmik's Avatar
I cannot get the ESP dance to work on my '07!! Am I supposed to hold the ESP button down the whole time or do you release it and re-press for each step? Just spent 30 min trying to get it to work to no avail.
Old 05-30-2012, 03:43 PM
  #113
Tx98Formula's Avatar
Hold it for 7 seconds and release for each step.
Old 05-30-2012, 03:46 PM
  #114
Fivepack1966's Avatar
Keep trying it it took a lot I mean a lot of tries to get it to work on my 11 jku
Old 05-31-2012, 09:45 PM
  #115
Finally got the "steering wheel dance" to work! Now has anyone figured out a way to turn off the stupid chime whenever you come to a stop?
Old 05-31-2012, 09:49 PM
  #116
shag7265's Avatar
What dance are u speaking of?
Old 05-31-2012, 10:28 PM
  #117
Turn ESP OFF COMPLETELY
1. Turn jeep on
2. Set to 4hi
3. Set parking brake
4. Make sure steering wheel is centered
5. Turn wheel to the right, 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, you may hear a chime at 5 seconds(and ESP OFF may show up on the speedo), but keep holding for 7 seconds!!!!
6. Turn wheel back to center then left 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, again, hold for 7 seconds!!!
7. Turn back to center, and hold ESP for 7 seconds.
8. Turn Jeep off
Old 06-01-2012, 07:53 AM
  #118
DeucesALLin's Avatar
Default Cant seem to get this...
Originally Posted by Freewill
Found this posted by another forum member. Sorry, I lost track of the OP's handle.
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes. If your Jeep JK Wrangler has logged any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s).
3. If your Jeep JK Wrangler has not logged any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
The link on PROJECK-JK is gone too, or the page is down at least. Someone please help.
Old 06-02-2012, 05:49 AM
  #119
Cozmik's Avatar
Thanks. I'll give it another bunch of goes today.
Old 06-02-2012, 12:00 PM
  #120
bodhi117's Avatar
Did the keyless entry reprogramming. Worked great... awesome thread.
Quick Reply: Disable/Enable feature codes/sequences
