Diagnostic Trouble Codes (DTC) How to Check Them & What They Mean
Old 07-15-2011 | 02:34 AM
  #31
Sigman's Avatar
Originally Posted by JdTms11
where are the codes?!
ive got 4 right now
P0513
P2299
P0562
P0706
Got them for you!
P0513 Incorrect Immobilizer Key
P0562 System Voltage Low
P0706 Transmission Range Sensor Circuit Range/Performance
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
Old 07-18-2011 | 11:16 AM
  #32
SFBayArea's Avatar
None of the links posted in this post working for me :-(.
Old 10-13-2011 | 09:00 AM
  #33
Colorado Chris's Avatar
Default Ditto for me
i tried getting to this as well and it says the article is not available anylonger. has it been removed. i really need to figure out if i have a failing wheel sensor.
Old 10-13-2011 | 11:51 AM
  #34
Hypertech's Avatar
Sponsoring Manufacturer
Hypertech Representative
http://www.aboutautomobile.com/DTC This link works on all makes and models
Old 12-11-2011 | 06:03 PM
  #35
Jeep Hound's Avatar
Thanks to the advent of technology, just about every single part on your new Jeep JK Wrangler is wired up to a computer. And, if anything goes wrong with any one of these parts, your Jeep’s computer will make a note of it and/or even let you know about it by illuminating a Malfunction Indicator Light (MIL for short or ‘check engine’ light) or icons on your dash. Unfortunately, the MIL or other icons won’t tell you a whole lot other than the fact that your Jeep is having some kind of a problem and unless you take your Jeep into the dealership or have a OBDII reader handy, you’re pretty much out of luck, right? Wrong. As luck would have it, the JK Wrangler’s come with a Diagnostic Trouble Code (DTC) reader built right into the dash and you can access them by following the 3 simple steps below. Once you have the DTC code(s) in hand, check it/them against the list below and you will be able to find out exactly what problems your Jeep is having.
Jeep JK Wrangler Diagnostic Trouble Codes - DTC
This information is no longer on the site,,,? Where else can i get this information?
Thanks
Quick Reply: Diagnostic Trouble Codes (DTC) How to Check Them & What They Mean
