Show your 33's
#897
Is that what will get damaged running 33's with no lift? the fenders? I keep seeing that'll rubbing with fully turned. Looking to running a 33's but just for the street/light trails for now, nothing crazy.....
#898
Shouldn't need a lift for 33s and should only need the spacers if you want to run a fat tire (285mm width/11" width or larger.) I run 255mm width and have no rubbing problems on stock rims, connected or disconnected. Technically they're a bit taller than the more common size in the BFG MT (33.3" for 255/85, 33.1" for 285/75.)
